681 - 700 of 835 Posts
For those of you using an MD TCM successfully behind a cummins, can you tell me what pins you hooked your analog 0-5v into? I know one guy on here was successful with that, but I think he deleted his account bc of conflict with his work. Also, does or can the MD cal TCM support the grounding pin for Low Speed Input when shifting into 4 Lo? I'm assuming the factory flash may not have that since I don't know any MD cal's that us 4WD with low.
If no one has been successful with the MD tcm and analog throttle input, what did you end up sing for throttle input? Could you just source a J1939 Throttle pedal with J1939 CAN module and hook that into the TCM input?
I'm not concerned with tap shift, and it seems the people on here with the GM TCM have had good luck with access to EFILIVE, but I'm trying to avoid that setup if possible since I don't have access to it. Appreciate the input.
What year is the trans/TCM?
2006 Trans, don't have TCM yet. I noticed Oxman504 had both setups in different trucks, and mentioned in #639 that he thought the simplest route was just the MD cal, and I think even Dale mentioned the same thing, though he has the GM Cal. Just trying to decide which one to buy and then I can wire accordingly and order the appropriate TPS sensor.
I switched to a 2003 w5500 MD Allison TCM 29537441 and finally got a CAT TPS to read. I tried to get a TPS to work with my IH 4700 J1939 TCM using Allison DOC software but I could not switch input types. Allison 2000 is going behind a P pumped 6BT in my 86 K30 eventually.
I'm looking at putting an Allison 6 speed behind an OM904 diesel. Since this is an MBE900 in the USA the best bet would be to get an MD TCM from behind one of those as the shift points should be set correctly. I've read through the entire thread a few times and was hoping someone could confirm the following.
1. I know the GM TCM can have a 4 low setting for the transfer but can this be set in the MD TCMs if I purchase Allison DOC?
2. In 4 low does the TCM use the output speed to do its calculation or does the transfer case ratio have to be manually entered via Allison DOC/EFI Live?
3. Does the TCM (either GM or MB) have any control over the PTO?
4. Finally to confirm all MD TCMs require an analog TPS input, correct?. Ironically the TPS for the mercedes engine supplies two PWM outputs, one for the ECU and I assume the other is for a TCM.
I ask all this as it determines whether I go an MD TCM or a GM TCM. My preference is the MD as it is easier and Allison DOC appears cheaper than EFI Live (unless I'm reading the pricing wrong). Really the ability to set 4 low for the transfer case is the deciding factor that I need clarified. On a side note what would happen if the transfer was put in 4 low without that particular setting in the TCM? Would it over-rev or just continually cycle gears?
Thanks,
John
Is your vss sensor in the transfer case are trans tail shaft you don't need to worry about 4 low cal.If the sensor is in the transmission.
Dale
Anybody came up with a gear indicator and a tow/haul signal for a light for the 6 speed trans yet? Back to working on the dash on my crew cab chevy swap and would like to put a tow/haul light and a gear indicator in the little box above the cluster where the glow plug and water in fuel lights are currently located.
The upfitter pdf should still be available on the internet at the GM upfitter site, have to look for it. Suppose I could take a picture of the scan of the second schematic in post #89 and email it to you, still don't have any web hosting to be able to post a picture. -Chuck.
Discussion starter · #699 ·
For some reason I cannot edit my older posts to update the link. Here's the 06 wiring diagram:
DUD 45, regarding your question about all MD tcm's requiring a TPS input, some do and some dont..., the early ones connected to a mechanical injection engine require a tps input, latter ones with electronic control injection management dont recognize a tps signal. thats at least what i discovered when i did mine.
On a side note, my TCM is MD allison 5speed program, i was curious if a tap shift would work but was told by one of the tap shift kit manufacturer that it would not work as my tcm is not gm and the plugs and terminals are different.... i thought all 5 speed 3rd gen tcm's were physically the same and all terminal locations had the same function being gm or otherwise, the only difference is that some terminals are ...or are not used depending on program.
