Cylinder Liners (4BD2, but same part for 4BD1 & T).
LINER; CYL BLK (1-11261-240-0)
OD Grade 1, ID Grade AX
LINER; CYL BLK (1-11261-241-0)
OD Grade 1, ID Grade CX
LINER; CYL BLK (1-11261-242-0)
OD Grade 2, ID Grade AX
LINER; CYL BLK (1-11261-243-0)
OD Grade 2, ID Grade CX
LINER; CYL BLK (1-11261-244-0)
OD Grade 3, ID Grade AX
LINER; CYL BLK (1-11261-245-0)
OD Grade 3, ID Grade CX
LINER; CYL BLK (1-11261-246-0) (This was mis-spelt 6INER in the description)
OD Grade 4, ID Grade AX
LINER; CYL BLK (1-11261-247-0)
OD Grade 4, ID Grade CX
All these part numbers from:
https://www.isuzunprparts.com/produ...sAccessory=0&isPerformance=0&searchTerm=liner
Price for all was $US143.03 each
AX/CX refers to piston grades to match installed liners. Measure liners 20mm down and 105mm down with 4 points each (8 total). Average these values.
Pistons are measured diameters below oil ring but above gudgeon pin hole at 90 deg to gudgeon pin hole.
Grade A is 102.02-102.04mm Liner ID
Grade A is 101.955-101.974mm Piston OD
Grade C is 102-04-102.06mm Liner ID
Grade C is 101.975-101.994mm Piston OD
Obviously if you're outside these measurements you have a problem!
Grade 1-4 is the bore size based on 0.01-0.019mm interference between liner and block. Two methods are described in different manuals.
First is using one measuring point is 115mm down from the deck. Measure 4 points (X, Y and 2 diagonals) and average.
Second is using 3 heights (20, 105 and 195mm down) and taking two measurements at each height.
Measurements are averaged in each case.
Grade 1 105.001-105.010 Block ID 105.011-105.020 Liner OD
Grade 2 105.011-105.020 Block ID 105.021-105.030 Liner OD
Grade 3 105.021-105.030 Block ID 105.031-105.040 Liner OD
Grade 4 105.031-105.040 Block ID 105.041-105.050 Liner OD
