The engine was just fully rebuilt, all that was done during the rebuild process. No exhaust in the radiator I’ve already checked that. Re working the heads would just be a precautionary, so there’s no guessing. Transmission is old and worn out that may be putting extra stress on the engine. Diesel engines run at lower RPM’s and tend to generate less heat then gas powerd engines. A Cummins is hard to beat, and from what I understand the easiest swap would be to go with a BT. The 350 I had just couldn’t handle a 10,000 lb trailer load, so I rebuilt the 383.
