Correct. The other spring on the throttle arm is to prevent you from breaking the arm off when you stand on the right pedal!So once it hits the first stop, that is max throttle correct?
Jcrow,So once it hits the first stop, that is max throttle correct? the throttle lever apprears to move about 45* at the first stop, then all the way is about 60*
I am putting together linkage for the 700r4 TV cable. So total sweep on a 4bt is 45* a gasser is 90* I will have to make the linkage account for this.
