1 - 1 of 1 Posts
Vendor
All-terrain tires are perfect for the drivers looking for a compromise between the off-road performance and highway driving comfort. These tires offer the best of both worlds - open-tread design common for the off-road tires that ensures a confident grip on country roads, and excellent on-road comfort. Below are 5 of the most common all-terrain tire options available for your Dodge Ram.
#1 Cooper Discoverer AT3
Features:
  • Saw-tooth grooves and serrated steps create biting edges for traction and dislodge stones and debris. This gives you excellent grip, self-cleaning ability, and reduced stone retention
  • Compounds are formulated with the highest content of chemically-coupled silica for maximum wet traction
  • High tensile construction provides maximum strength and more protection with a higher load capacity
#2 Falken Wildpeak Tires
Features:
  • Interlocks the shoulders to resist wear from high torque and provide additional handling stability
  • Protects the tire from sharp rocks and provide additional off‐road traction at low tire pressures or in off‐camber situations
  • Delivers superior wear life and wet performance (non‐LT sizes)
  • Provide tread-pattern rigidity in the contact patch, enhancing vehicle stability and handling while also preventing stones from becoming trapped in the grooves
#3 Kumho Road Venture AT51
Features:
  • Engineered for a quiet, comfortable ride, with a symmetric tread design and variable-pitch tread blocks to reduce road harmonics
  • Excellent grip and stability in heavy weather, with deep central grooves to channel rain and snow away quickly
  • For long tread wear and fuel efficiency, the dual silicone compound is engineered to cool quickly and wear evenly
#4 General Grabber AT2
Features:
  • Innovative tread design promotes uncompromising off-road traction
  • Designed to increase tread life
  • The highly-engineered acoustic tread pattern allows the aggressive tread pattern to remain quiet during road and highway driving
  • Select sizes meet the severe snow service requirements of the RMA and RAC
#5 BFG All Terrain KO2
Features:
  • Split and bruise resistant sidewall rubber, derived from BFGoodrich's race proven Baja T/A®KR2 tire
  • Increased rubber thickness, extending down the sidewall to protect more of the critical sidewall failure zone
  • Raised bars in the shoulder tread help to release compacted mud for enhanced traction in muddy and soft soil conditions
1 - 1 of 1 Posts
