O.K. On to the next step of the build....I'm starting a separate thread to help those that are searching for similar answers at a later date. Once I've made a selection, I'll move back into my build thread.
Engine is running and it's time to begin sourcing the big parts that go behind the engine. Tranny, Tranny Controller & Torque Converter.
Although I have a couple of auto vehicles in the stable, I've really never had to work on any of the auto tranny's. For my 4BD1T build I've chosen to use a GM 4l80e transmission and now I need some suggestions for the parts above.
I found a local guy who will re-build a 4l80e for about $1100 out the door which includes his core charge ($850 for the tranny plus $250 core charge). He says it will hold 500 ft lbs just fine and knows I intend to put the tranny behind a diesel.
He's recommending a stock GM diesel torque converter which has a stall around 1600 rpm I believe.
Because my flywheel is comparatively on the light side of the spectrum (25 lbs), I'm thinking I might need to bump my idle to 50 or 100 rpms above stock setting to smooth out the engine a little. I don't want a shaky vehicle when I'm sitting at a stop light. If I bump the idle rpms and have a really low stall, I could be fighting the engine while at a stop light so I'm trying to get this part of the build right and I don't see much data on this forum about what stall to get.
So, here are my questions...
1. What do you recommend for a stall speed and what or whose brand torque converter should I be looking for?
2. Who's 4l80e tranny controller do you like the best? I'd prefer user friendly, reliable and ease of programmability over price.
Thanks,
Adam
Thanks,
Adam
