has anyone tried to use the fuel torque plates from the 12v on the 4bt? just curious if we could use those on the motor......
You don't need no stinkin' fuel plate!ahhh well no i have a VE pump but thats still helpful info for someone.
just FYI, you can crank up a P7100 pump for free... grind your own plate, etc.You don't need no stinkin' fuel plate!
You can crank these pumps up easily for $0 and that is nice (free)
http://www.dodgeram.org/tech/dsl/more_power/Power_ve.htm
Might want to buy a 366 spring, though. It is nice to have.
Too hard to find and too expensive for the "average" 4BT user, tho...and they put out more fuel to boot
so very trueToo hard to find and too expensive for the "average" 4BT user, tho...
How the hell do those work?
Is there something inside the pump that follows along that jagged edge???
The gov lever rides along the edge of the fuel plate.That's what I'd like to know too...
OK im following nowThe gov lever rides along the edge of the fuel plate.
Scott
Leave the plate in !you can remove the plate all together, has the same effect as a #0 plate.
