1 - 20 of 24 Posts
Wheel Automotive parking light Tire Automotive side marker light Car
Hey folks, I've been working on a 4bt swap in my 1984 Toyota Land Cruiser, and have it nearly finished, with the only things left being A/C hoses, Electric fan wiring, and vacuum assist for my brakes.
The thing that is killing me at the moment, is not being able to spin my engine fast enough for it to start.
My setup is a 93ish 4bt with VE pump, with an adapter and bell housing attaching it to an NV4500, which is then adapted to my stock FJ60 transfer case. All this stuff was running in another Land Cruiser about 6 months ago, and was removed in favor of a Chevy LS drivetrain.
I'm not sure which starter I have, and I know my little battery isn't enough power, but even trying to jump the thing with another car, it won't spin fast enough to start.
I currently have 2 big ground cables going from the battery to the engine, and one big one going from the engine to the body, as well as a couple of smaller ones going from the transfer case to the body.
Do I need a ground directly from the battery to the ground? Do I need another ground going from the body to the frame, or from the drivetrain to the frame?
I was considering adding a ground from the frame directly to one of the starter mounting bolts, as well as one directly from the battery to the fender.
My positive cable is 0 ga cable going straight to the starter, and a 10 ga or so going to the dash/fuse panel, etc...
I'm very close to driving this thing, but simply can't get it to start. Would a bigger battery solve my issue on its own, even if jumper cables and another car didn't?
Currently everything is setup as 12v. I dont think I have a 24v starter, but would probably replace it if I could figure out what to buy...
Tire Wheel Car Vehicle Hood
Motor vehicle Vehicle Automotive lighting Hood Car
Automotive tire Motor vehicle Plant Automotive exterior Gas
Automotive fuel system Automotive tire Vehicle brake Hood Motor vehicle
Put a volt-meter on the starter hot wire and starter body while cranking. That'll tell you how many volts the starter is getting under load.
If it's getting close to 12V and not pulling much current then you might have a 24V starter!
If it's not getting close to 12V you've got either a grounding issue or power supply issue.
My personal preference is for the main ground cable to go direct to a starter bolt from the battery. That looks like an N70 battery so should be enough if in good condition. These LOVE large cables.
Product Font Material property Parallel Pattern
The preferred grounding on a Cummins is battery direct to engine block and then engine block to frame. The starter of course will be grounded to the block. Jumper grounds can go from the frame to various body parts. On cable size, the preferred is 2/0 positive and ground cables. That would be twice as big as you 1/0. No such thing on these creatures as too big when it comes to cables. Slow cranking on these engines can be one of several possible issues as has been pointed out. Cables too small (your 1/0 is probably OK), bad wire connection (possible corrosion), weak battery, or weak starter. If you had this engine running in a vehicle previously, the starter probably isn't the wrong voltage but never hurts to check. There appears to be an ID tag on the starter so you should be able to verify that.
Discussion Starter · #6 ·
Thanks for your help, guys!
I ordered 20 ft of new 1/0 welding cable today and some crimp on lugs.
I'll start over with new battery cables, both terminating at the starter, as well as grounds going battery to body, body to frame, engine to frame, and engine to body. If that lets me start the engine with either my small battery alone or with a jump, then I'll just stop at a bigger battery. If not, I'll have the starter tested, and decided from there whether to replace the starter or add a second battery. I'm tempted to have a friend pull start me at this point haha. I want to drive this thing sooooo bad!
You can run a single battery on these engines but 2 can be nice especially if you live in a cold climate area. A single should be in the size of 800 CCA. The early Dodge Cummins 6bt had a single but it was around 1000 CCA or a tad more. They soon decided duals were better. The one drawback on duals is if one battery gets weak you have to replace both.
I have been running a single 800 CCA starting battery and it has worked well, but I have a second battery that runs everything but the engine so in winter the grid heater is powered by the second battery and I'm not sure that the single battery would deal with the draw of both starter and grid heater. I like the redundancy of a split charging/storage in a trial rig...$.02
Discussion Starter · #9 ·
Thanks guys. I do intend to add a second battery, but was hoping to get the thing running and do that once I knew I had a viable vehicle again. I have a ton of work left to do to this thing, but I need to be able to at least start it and move it around the yard for now.
I ordered 15 more ft of 1/0 welding cable, and will make battery cables with that that go directly to the starter, as well as adding a few more grounds. I'll buy a new battery with at least 1000 cranking amps and try to get the thing running again, and in a couple more weeks I'll buy another battery and a mounting tray...
These things normally start super easy. I would make sure that your shut off solenoid is getting power and the fuel system is bled. My 4B with a VE pump will start fine with a nearly dead battery!
Reactions: Thechief86
Discussion Starter · #11 ·
Today I made up some new cables, and tomorrow I will install them and try again to start the engine.
This thing was running in another truck 6 months ago or so, but has been sitting since then. It may need fuel lines bled and all that, I'm not sure. I'm still hoping that I can get it to spin faster than it does, as I currently get maybe 2-3 full rotations before it stops, and will do the same again after cooling off, even with another car hooked up with jumper cables....
2-3 rotations and then it stops is beginning to sound like a stater problem, but it could be wiring as well. If the new wires don't cure the problem a starter rebuild may be needed. Have you had the battery tested?
Discussion Starter · #15 ·
I haven't had anything tested, but the starter was in daily use until 6 months ago in my friend's truck, attached to the same engine, just yanked out and swapped into a different vehicle.
The battery is probably a year old, but was in daily use in this same vehicle with the gas engine before I yanked that out.
I'm heading outside to install the bigger cables now, and will try starting again with a hot battery. If that doesn't get it, I'll replace the starter. I have been too busy to try anything else for the last week, but maybe we can get somewhere today.
Discussion Starter · #19 ·
Yeah it starts super easy now, I've just gotta figure out fuel leaks on my return line now.
It drives really well, though, and pulls hills even better than the Toyota 6 cylinder that was in it.
Over the next few months I'll keep putting it back together and improving fit and finish as I go. I still have a ton of work to do to the truck itself, and still need to get my vacuum stuff working for brakes so I can drive it until I'm ready to upgrade to hydroboost.
I also need to get the exhaust put together, as right now I only have the downpipe directly off the turbo, so only about 30" of 3" pipe and nothing else. It's loud as heck.
I have all the pipe and a good muffler, and the rear section is already bent to go over the axle and turn out, I just need to weld hangers on and either clamp or weld the mid section in.
I'm on the fence about welding that part in case I need to remove it, but I worry clamps will leak and sound terrible.
On the exhaust, whether you weld it all up or use clamps is your call. There are clamps that don't leak. A bit more expensive than the plain ones you get at the muffler shop but they work. 3" ones run in the $9 and up range depending on size and material. These are what you often find on big trucks. They come in versions that join equal size pipes and unequal sizes.
Automotive lighting Gas Audio equipment Auto part Metal
1 - 20 of 24 Posts
