1 - 3 of 3 Posts
Okay, so I'm doing research into a 6BT swap into a '65 - '67 Lincoln Continental and before i start the project, I want to have all the foreseen needed parts. So my question is this; if I swap a 6BT into the Continental, what would be the best transmission to use? I would prefer a manual, since its just more fun to me. I also intend to do new injectors, fuel pump and a larger turbo. The purpose of this car will be to tool around town and be able to put my foot down and give a new 5.0 a spankin'. I honestly don't know very much about the diesel world, as I've mostly played with big block mopars and built imports. I figure that since i have two fast as hell race cars, I should build something off-the-wall and classy. I thought about doing a 632 stroker, but I've never built a diesel and I wanted to try something new. But now that's I have come to the research stage of the build, the tranny could possibly make or break this build. So based on these purposes, what would be the best options?
The best combo for that car is a 460 w/c-6. Saves probably400 lbs. Probably won't spank many people but surprise many. That combo is the cheapest hp for that platform. Stroker is best next level--on the street, that might beat 3 outa 4 takers. Sounds like you already know what a stroker might cost. Now multiply that figure by 3 and you may get a diesel to hang with it---maybe.
diesel racing ain't cheap. go fast is best left to gassers.
Crawl under the lincoln, and look for a frame--not there, huh. That's the first problem, but not insurmountable. Figure a cage, subframes, and a 4-link to keep torq from twisting that bigmobile in two.
Put a stock 4bt in it, putt around, and brag about your fuel milage. That in itself is plenty cool enough.
Then you'll be in diesel world.
1 - 3 of 3 Posts
