1 - 20 of 22 Posts
Link to ZF transmission specs PDF files:
ZF S5-42 Reman Specs (29 KB)
ZF S5-42 Transmission Years (29 KB)
ZF S5-47 Datasheet (85 KB)
ZF S5-47 Service Tips (844 KB)
ZF S6-650 Datasheet (162 KB)
ZF Application Progression Chart (13 KB)
ZF Cross Reference Chart (116 KB)
5 & 6 Speed:
http://www.zf.com/content/en/import...roductDataBase/service/applicationLayerSelect
9 Speed:
12 & 16 Speed:
Quick Reference for ZF:
ZF Transmission Data Summary
S5-42 Gas Units
• Model Year 1987 - 1995
• 1992 and newer applications have the electronic speedo.
• On all 4 x 4 and Superduty applications, the speedo cable connects to either the parking brake or the transfer case.
• 1987-1991 4 x 2 applications have a 7 or 8 tooth speedo that connects via the transmission.
• 4 x 4 units are used in 4 x 2 superduty applications.
• If a 4 x 2 vehicle is equipped with electronic speedo, use O.E. speedo plug number F2UZ 7H183A.
• 1307 050 064ZW only used in UPS vehicles.
• S5-42 units are not interchangeable with S5-47 units.
• Gas units must use ZF recommended Dexron Il/MERCON® XT-2 QDX or DDX equivalent.
• Available in 4.9/5.8 engine as well as 7.5 Gas
• 5.72-.076 ratio
• 4WD: 31 spl output
• 2WD trans 619mm OAL to Flange
S5-42 Diesel Units
• Ratios avail 5.72-0.76 4.14-0.77
• 6.9 / 7/3 engines
• Model Year 1987 – 1994-1/2
• 4 x 4 units are used in 4 x 2 Superduty applications.
• 1307 050 103ZW only used in UPS vehicles.
• Diesel units must use ZF recommended Dexron Il/MERCON® XT-2 QDX or DDX equivalent
• 4WD: 31 spl output.
S5-47 Gas Units
• Model Year 1996 - 1997
• 1317 050 007 and 1317 050 013 [7.5 Gas Units] are 100% interchangeable.
(What is different about the 1317 050 006 7.5 unit?)
• S5-47 units are not interchangeable with S5-42 units.
• Gas Units are shown for 4.9/5.8 engine, as well as 7.5 engine
• all show 5.72-0.76 ratio
• 684mm OAL 2WD to ctr of u-joint in yoke
S5-47 Diesel Units
Ratio 5.08 1st; .77 reverse
S5-47M Gas Units
• S5-47M Model Year 1999 - current
• S5-47M units are not interchangeable with S5-47 units.
• Gas units must use Ford Synthetic Mercon E6AZ 19582-B or Castrol Transmax-S.
• Gas units used with 5.4 and 6.8 engines
• All show 5.72-0.76 ratio
Ford S6-650 Diesel
• Model Year 1999 – 2000
• Application 7.3L Diesel
• S6-650 standard torque transmissions may be replaced with the S6-650 High Torque transmissions.
• Diesel units must use ZF recommended Dexron II/MERCON® XT-2 QDX or DDX equivalent.
• 5.79-0.72 ratio
• Internal oil pump for lubrication and cooling
• Rated to 500 ft-lbs input torque
• Wt: 235 lbs
• 4WD: 24 spl output
S6-650 High Torque Diesel
• Model Year 2001 – current
• S6-650 High Torque transmissions may not be substituted with the standard torque transmissions.
• 5.79-0.72 ratios
• Rated to 520 ft-lbs input torque
• GCW 26,000 lbs.
• Wt: 235 lbs
Ford S6-650 Gas
• Model Year 2002
• Application 6.8/5.4 Gas
• Gas units must use ZF recommended Dexron II/MERCON® XT-2 QDX or DDX equivalent.
• 5.79-0.72 ratio
• OAL 842mm to flange 2WD
Ford S6-750
• Model Year 03-?
• 6S-750 Transmissions may not be substituted with the S6-650 transmissions.
• 6S-750 OAL 2wd 766.3mm
• 6S-750 ratios 5.79,3.30, 2.10,1.31,1,.72,5.23
• 6S-750 ratios dry wt 235lbs, oil cap 6.0L GCW 30,000lbs
• Rated to 560 ft lbs input torque
• Wt: 235 lbs
• Oil Capacity 6.0L
• 4WD: 34 spl output
Schlep
The transmission post / FAQ from our moderator BobS (thanks Bob!) which has awesome info about pretty much every trans out there!
This post is taken from our FAQ in the Main Section...
PLEASE BOOKMARK THIS THREAD FOR FUTURE REFERENCES
______________________________________________________________
Transmissions & Convertors, Automatic, Topic Index
Allison:
http://www.4btswaps.com/forum/showthread.php?t=1340
http://www.4btswaps.com/forum/showthread.php?t=6693 <=Allison to B Series Cummins made easy
http://www.4btswaps.com/forum/showthread.php?t=6693 <=B Seriers Cummins to Allison & generic controller info
http://www.4btswaps.com/forum/showthread.php?t=8633 B Series Cummins to Duramax Allison & misc
http://www.4btswaps.com/forum/showthread.php?t=10615 <=545 info
http://www.4btswaps.com/forum/showthread.php?t=11810 <=More 545 info
http://www.4btswaps.com/forum/showthread.php?15428 <=The-complete-Allison-1000-2000-2400-info-and-swap-guide-thread
http://www.4btswaps.com/forum/showthread.php?18310 <=Making an AT545 Flex Plate Spacer HUB
http://www.4btswaps.com/forum/showthread.php?18276 <=Complete Allison 1000 build [WARNING: PICTURE HEAVY THREAD!!]
http://www.4btswaps.com/forum/showthread.php?21658 <=Allison md-3060 swap questions
Chrysler:
http://www.4btswaps.com/forum/showthread.php?t=201
http://www.4btswaps.com/forum/showthread.php?t=251
http://www.4btswaps.com/forum/showthread.php?t=377
http://www.4btswaps.com/forum/showthread.php?t=424
http://www.4btswaps.com/forum/showthread.php?t=891 <=727 version differences
http://www.4btswaps.com/forum/showthread.php?t=1160 <=Gasoline vs Diesel, 1st Gen Gas models DO NOT fit Diesels
http://www.4btswaps.com/forum/showthread.php?t=1281 <=47RE
http://www.4btswaps.com/forum/showthread.php?t=2555 <=Flexplate discussion
http://www.4btswaps.com/forum/showthread.php?p=20793#post20793 <=External links to trans information <=External links to trans information
http://www.4btswaps.com/forum/showthread.php?t=2601 <=47RH rubber mounts
http://www.4btswaps.com/forum/showthread.php?t=3015 <=47RH controlling OD
http://www.4btswaps.com/forum/showthread.php?t=5293 <=47RH converter lockup in 2nd gear
http://www.4btswaps.com/forum/showthread.php?t=5611 <=47RE to RH converting & differences
http://www.4btswaps.com/forum/showthread.php?t=7315 <=46RH & 47RH & parts info
http://www.4btswaps.com/forum/showthread.php?t=7398 <=47RH Pigtail connector source
http://www.4btswaps.com/forum/showthread.php?7398-47RH-Pigtail-connector <=47RH Pigtail connector additional sources
http://www.4btswaps.com/forum/showthread.php?t=7663 <=727 with Cummins throttle kick down linkage set up
http://www.4btswaps.com/forum/showthread.php?t=10738 <=47RH Pic rebuild
http://www.4btswaps.com/forum/showthread.php?13217 <=47RH to NP208 & NP242D
http://www.scribd.com/mobile/documents/228727 <=A500 42RH A518 46RH A618 47RH Service Manual
http://www.4btswaps.com/forum/showthread.php?24793 <=46rh converter pilot to long for 4bt crankshaft relief
http://www.4btswaps.com/forum/showthread.php?27988 <=01 Durango 4BT 47RE-No-overdrive
Ford:
http://www.4btswaps.com/forum/showthread.php?t=437
http://www.4btswaps.com/forum/showthread.php?t=2992 <=Mounting pattern interchanges & misc.
AOD:
http://www.4btswaps.com/forum/showthread.php?t=913
http://www.4btswaps.com/forum/showthread.php?t=2505
http://www.4btswaps.com/forum/showthread.php?t=4449
C6:
http://www.4btswaps.com/forum/showthread.php?t=9576
E4OD:
http://www.4btswaps.com/forum/showthread.php?t=1324
http://www.4btswaps.com/forum/showthread.php?18183 <=E4OD to Cummins=Cheap Happiness
4R100:
http://www.4btswaps.com/forum/showthread.php?27267 <-auto 4bt awesome
http://www.4btswaps.com/forum/showthread.php?27898 <=Gas vs Diesel versions of the 4r100
General Motors:
Governor Interchangeability Between Models:
http://www.4btswaps.com/forum/showthread.php?t=1631&page=2;post=15501
400/475 Turbo:
http://www.4btswaps.com/forum/showthread.php?t=204
http://www.4btswaps.com/forum/showthread.php?t=143
http://www.4btswaps.com/forum/showthread.php?t=457
http://www.4btswaps.com/forum/showthread.php?t=454
http://www.4btswaps.com/forum/showthread.php?t=1317
http://www.4btswaps.com/forum/showthread.php?t=1392
http://www.4btswaps.com/forum/showthread.php?t=3016 <=2WD TH400 bolts onto NP205 32 spline
http://www.4btswaps.com/forum/showthread.php?t=3882 <=Convert 2WD to 4WD
http://www.4btswaps.com/forum/showthread.php?t=4625 <=2WD P30 to 4WD
http://www.4btswaps.com/forum/showthread.php?t=10283 <=Adjusting shifting modulator bolt
http://www.4btswaps.com/forum/showthread.php?5463 <=GM & Ford P30 4BT flexplate part #'s
http://www.4btswaps.com/forum/showthread.php?15194 <=Duramax to TH400 info
http://www.4btswaps.com/forum/showthread.php?19014 <=Question about how to remove a Turbo 475 auto from the engine
4L80E:
http://www.4btswaps.com/forum/showthread.php?t=543
http://www.4btswaps.com/forum/showthread.php?t=1178 <=Also covers years, with other GM trans info.
http://www.4btswaps.com/forum/showthread.php?t=1318
http://www.4btswaps.com/forum/showthread.php?t=3627
http://www.4btswaps.com/forum/showthread.php?t=5021
http://www.4btswaps.com/forum/showthread.php?t=6112 <=4L80E factory transmission controller part#
http://www.4btswaps.com/forum/showthread.php?t=6900 <=Shifting but not all wired up
http://www.4btswaps.com/forum/showthread.php?t=8223 <=4L80E convertor mounting to TH400 flexplate
http://www.4btswaps.com/forum/showthread.php?t=9287 <=Harness pin out, links to Pirate
http://www.4btswaps.com/forum/showthread.php?t=9478 <=Ultimate 4l80e info guide hydraulics, wiring, etc.
http://www.4btswaps.com/forum/showthread.php?23590 <=Wiring & plug pin out info
http://www.4btswaps.com/forum/showthread.php?23670 <=4L80e Budget Tunable Controller
700R4:
http://www.4btswaps.com/forum/showthread.php?t=172
http://www.4btswaps.com/forum/showthread.php?t=691 <=Custom Converter=
http://www.4btswaps.com/forum/showthread.php?t=2289 <=Constant pressure valve body
http://www.4btswaps.com/forum/showthread.php?t=2995 <=From a 6.2L diesel?
http://www.4btswaps.com/forum/showthread.php?t=5145 <=Problems [failed behind 4BT]
http://www.4btswaps.com/forum/showthread.php?17448 <=Pro's & cons + weak points to fail
Jeep:
http://www.4btswaps.com/forum/showthread.php?t=2391 <=Aisin Warner 4 speed auto
General Information, Aftermarket Controllers:
http://www.4btswaps.com/forum/showthread.php?t=3120
http://www.4btswaps.com/forum/showthread.php?t=3960 <=Transmission temperatures & coolers
http://www.4btswaps.com/forum/showthread.php?t=4234 <=Controller sources
http://www.4btswaps.com/forum/showthread.php?t=4639 <=Choosing which automatic transmission to use
http://www.4btswaps.com/forum/showthread.php?t=7948 <=Torque converter to flex plate mounting questions
http://www.4btswaps.com/forum/showthread.php?t=8231 <=4BT crankshaft flexplate spacer removal
http://www.4btswaps.com/forum/showthread.php?t=11030 <=4L80E Controllers
Transmissions & Clutch, Bellhousings, Manual, Topic Index
General Information and Options:
http://www.4btswaps.com/forum/showthread.php?t=737 <=Options and Choices, Various
http://www.4btswaps.com/forum/showthread.php?t=841 <=GM & Ford stepvan trans info & identification
http://www.4btswaps.com/forum/showthread.php?t=852 <=Dual trans
http://www.4btswaps.com/forum/showthread.php?t=1111 <=Comparing differences
http://www.4btswaps.com/forum/showthread.php?t=1224 <=T-19 to NV4500
http://www.4btswaps.com/forum/showthread.php?t=1235 <=Clutch linkage, Hydraulic & Mechanical Choices
http://www.4btswaps.com/forum/showthread.php?t=1439 <=Starter spacer on GM adapters cast into adapter
http://www.4btswaps.com/forum/showthread.php?t=1597 <=SAE bellhousings
http://www.4btswaps.com/forum/showthread.php?t=2808 <=Flywheel shims?
http://www.4btswaps.com/forum/showthread.php?t=3220 <=Not enough clearance for fork travel
http://www.4btswaps.com/forum/showthread.php?t=3255 <=Slave cylinder, how to bleed air out
http://www.4btswaps.com/forum/showthread.php?t=7364 <=Flywheel mounting bolts info & part#'s [used in standard shift P30]
http://www.4btswaps.com/forum/showthread.php?24250 <=Using a Ford flywheel & Clutch w/Chevy transmission part #'s
By Manufacturer:
Borg Warner, T18, T19 (aka "Ford set up"), and Ford ZF:
http://www.4btswaps.com/forum/showthread.php?t=126
http://www.4btswaps.com/forum/showthread.php?t=390
http://www.4btswaps.com/forum/showthread.php?t=510
http://www.4btswaps.com/forum/showthread.php?t=527
http://www.4btswaps.com/forum/showthread.php?t=545
http://www.4btswaps.com/forum/showthread.php?t=1469 <=T19
http://www.4btswaps.com/forum/showthread.php?t=7128 <=Hydraulic clutch info
http://www.4btswaps.com/forum/showthread.php?t=7753 <=T19 Clutch kit part numbers
http://www.4btswaps.com/forum/showthread.php?t=12692 T19 Hydraulic clutch pics
ZF:
ZF Transmission Manuals
ZF S5-42 Datasheet (69 KB)
ZF S5-42 Diagnosis and Testing Manual (758 KB)
ZF S5-47 Description and Operation Manual (800 KB)
ZF Clutch Manual (66 KB)
E4OD to ZF 5 Speed Conversion Guide (24KB)
ZF Wiring Diagram 1 (29 KB)
ZF Wiring Diagram 2 (29 KB)
ZF Wiring Diagram 3 (27 KB)
http://www.4btswaps.com/forum/showthread.php?t=703 <=Good ZF info=
http://www.4btswaps.com/forum/showthread.php?t=828 <=ZF Diesel gear set into small pattern case
http://www.4btswaps.com/forum/showthread.php?t=1026 <=ZF S6-650 to NP205
http://www.4btswaps.com/forum/showthread.php?t=1022 <=ZF to NP205 & BW xfer case
http://www.4btswaps.com/forum/showthread.php?t=1817 <=Diesel ZF
http://www.4btswaps.com/forum/showthread.php?t=2545 <=ZFS5-42/47
http://www.4btswaps.com/forum/showthread.php?t=2728 <=F-450 Diesel ZF5-42 Parking brake removal
http://www.4btswaps.com/forum/showthread.php?t=2910 <=ZF 6 speed size
http://www.4btswaps.com/forum/showthread.php?t=5158 <=ZF 6 Speed info
http://www.4btswaps.com/forum/showthread.php?t=6354 <=ZF exploding slave cylinder
http://www.4btswaps.com/forum/showthread.php?t=7003 <=Differences, vehicle sources & general info
http://www.4btswaps.com/forum/showthread.php?t=7641 <=ZF dimensions
http://www.4btswaps.com/forum/showthread.php?t=9465 <=ZF transfer case info
http://www.4btswaps.com/forum/showthread.php?t=9717 <=ZF hyd clutch line
http://www.4btswaps.com/forum/showthread.php?t=10597 <=Gen info
http://www.4btswaps.com/forum/showthread.php?t=11038 <=ZF transfer case options
http://www.4btswaps.com/forum/showthread.php?13213-4BT-and-a-ZF-5-speed <=BBF & diesel ZF to B Series Cummins
http://www.4btswaps.com/forum/showthread.php?12792 <=Trans brake removal to 4WD bolt on
http://www.4btswaps.com/forum/showthread.php?17790-Diesel-zfs-542 <=Steel adapter plate for Diesel Ford Trans
http://www.4btswaps.com/forum/showthread.php?23647 <=ZF5 to Ford NP205 pics
ZF Slave & Master Cylinder Info
o
http://www.4btswaps.com/forum/showthread.php?39306 <=ZF5 concentric slave & master cylinder info
ZF FAILURE:
http://www.4btswaps.com/forum/showthread.php?t=12971
Chrysler 89 - 93 Getrag G360 used in 6BT Dodges:
http://www.4btswaps.com/forum/showthread.php?t=2395 <=Getrag flywheel# for 13" Sachs Clutch
http://www.4btswaps.com/forum/showthread.php?t=4789
http://www.4btswaps.com/forum/showthread.php?t=7142 <=4WD to NP205
http://www.4btswaps.com/forum/showthread.php?t=10036 <=Getrag G360 with NV4500 parts mixing & why not to
http://pc-guy.ca/Dodge/Getrag-pdf/ <=Getrag G360 pdf file
G56
http://www.4btswaps.com/forum/showthread.php?22829 <=NV4500 to G56 behind 12 valve
Chrysler & GM A833 Overdrive 4 Speed:
Clark:
http://www.4btswaps.com/forum/showthread.php?18397 <=280VO I'm aggravated with CLARK
Ford NP435:
http://www.4btswaps.com/forum/showthread.php?t=11783 <=Mid 70's Ford using Getrag BH
Jeep & Others Using the AX-15:
http://www.4btswaps.com/forum/showthread.php?t=555
http://www.4btswaps.com/forum/showthread.php?16643-Mating-4bt-to-ax15
Mazda:
http://www.4btswaps.com/forum/showthread.php?t=921
http://www.4btswaps.com/forum/showthread.php?t=131 <=M5R2
http://www.4btswaps.com/forum/showthread.php?t=1838 <=M5R2
http://www.4btswaps.com/forum/showthread.php?t=3414
http://www.4btswaps.com/forum/showthread.php?t=7346 <=Slave cylinder size for M5R2
http://www.4btswaps.com/forum/showthread.php?t=10506 <=M5R2 Russ' Info
New Venture 3500:
http://www.4btswaps.com/forum/showthread.php?t=571
http://www.4btswaps.com/forum/showthread.php?t=6206
http://www.4btswaps.com/forum/showthread.php?t=8213
New Venture 4500
Chrysler:
http://www.4btswaps.com/forum/showthread.php?t=268
http://www.4btswaps.com/forum/showthread.php?t=490
http://www.4btswaps.com/forum/showthread.php?t=499
http://www.4btswaps.com/forum/showthread.php?t=582
http://www.4btswaps.com/forum/showthread.php?t=630
http://www.4btswaps.com/forum/showthread.php?t=1833 <=Balancer
http://www.4btswaps.com/forum/showthread.php?t=2210 <=Fifth gear problems
http://www.4btswaps.com/forum/showthread.php?t=2211 <=Cast iron tailhousing defects
http://www.4btswaps.com/forum/showthread.php?t=4453 <=Problems after assembly
http://www.4btswaps.com/forum/showthread.php?t=5112 <=Tailhousing swaps
http://www.4btswaps.com/forum/showthread.php?t=6343 <=NV4500 to Dana 300 how to
http://www.4btswaps.com/forum/showthread.php?t=6580 <=94-01 bellhousing component part #'s
http://www.4btswaps.com/forum/showthread.php?t=7142 <=NV4500 to NP205
http://www.4btswaps.com/forum/showthread.php?t=7431 <=1992 Dodge application
http://www.4btswaps.com/forum/showthread.php?t=7650 <=GM NV4500 to Dodge input retainer mod
http://www.4btswaps.com/forum/showthread.php?14995 <=-Dodge 4x4 nv4500 aluminum-tailhoushing part#
http://www.4btswaps.com/forum/showthread.php?15214 <=transmission mount comparison
New Venture 4500 to FORD:
http://4btswaps.com/forum/showthread.php?t=4042
http://www.4btswaps.com/forum/showthread.php?t=6276
New Venture 4500:
General Motors:
http://www.4btswaps.com/forum/showthread.php?t=354
http://www.4btswaps.com/forum/showthread.php?t=504
http://www.4btswaps.com/forum/showthread.php?t=507
http://www.4btswaps.com/forum/showthread.php?t=542
http://www.4btswaps.com/forum/showthread.php?t=937
http://www.4btswaps.com/forum/showthread.php?t=4285 <=NV4500 Bellhousing to trans mounting different from P30 SM465 trans
http://www.4btswaps.com/forum/showthread.php?t=10750 <=Variants with mixing and matching parts
http://www.4btswaps.com/forum/showthread.php?18931 <=92 odd pattern GM NV4500 replacing SM465 behind a 4BT
http://www.4btswaps.com/forum/showthread.php?21372 <=GM 4500 using P30 Step Van adapter the facts
http://www.4btswaps.com/forum/showthread.php?23509 <=Re-drilling Transmission Bolt Pattern to Fit Early Pattern Bellhousings
http://www.4btswaps.com/forum/showthread.php?45314 <=early-NV4500 to SM465-bellhousing
http://www.4btswaps.com/forum/showthread.php?26882 <=The 95 GM/Chevy NV4500 QUAGMIRE!
New Venture 5600:
http://www.4btswaps.com/forum/showthread.php?t=2231 <=Going from the 4500 to 5600
http://www.4btswaps.com/forum/showthread.php?t=3619 <=Years & clutch sizes
Roadranger, Eaton, Fuller & SAE
http://www.4btswaps.com/forum/showthread.php?t=1974
http://www.4btswaps.com/forum/showthread.php?t=2102
http://www.4btswaps.com/forum/showthread.php?t=6668 <=Fuller & RR
http://www.4btswaps.com/forum/showthread.php?t=6673 <=Fuller & part#'s for Ford medium duty w/6BT
http://www.4btswaps.com/forum/showthread.php?t=9162
http://www.4btswaps.com/forum/showthread.php?t=10129
http://www.4btswaps.com/forum/showthread.php?t=11445 <=SAE Part#'s using SAE #2 to Roadranger
http://www.4btswaps.com/forum/showthread.php?14013 <=Where-are-the-SAE-3-Specs
http://www.4btswaps.com/forum/showt...-of-a-RT610-with-mounts-on-the-clutch-housing <=RT610
SM-420 GM 4 Speed:
http://www.4btswaps.com/forum/showthread.php?t=2913
SM-465 GM 4 Speed:
http://www.4btswaps.com/forum/showthread.php?t=697
http://www.4btswaps.com/forum/showthread.php?t=1425 <=Bellhousing to engine adapter bolt size
http://www.4btswaps.com/forum/showthread.php?t=2048 <=Strength, 6BT question
http://www.4btswaps.com/forum/showthread.php?t=354 <=GM van clutch & NAPA part number
http://www.4btswaps.com/forum/showthread.php?t=5500 <=SM465 with Dana 20 xfer case
http://www.4btswaps.com/forum/showthread.php?t=10180 <=Big medium duty input shaft & 4x4
http://www.4btswaps.com/forum/showthread.php?t=10731 <=Medium duty input shaft into SM465
http://www.4btswaps.com/forum/showthread.php?18506 <=SM465 Muncie 4 speed rebuild and repair, off site links to overhaul
Spicer:
http://www.4btswaps.com/forum/showthread.php?t=273
http://www.4btswaps.com/forum/showthread.php?t=2168
http://www.4btswaps.com/forum/showthread.php?t=5148 <=Parts sources
http://www.4btswaps.com/forum/showthread.php?t=2168 <=Adapting to Dana 300
http://www.4btswaps.com/forum/showthread.php?t=7161 <=3053A to Cummins B Series
http://www.4btswaps.com/forum/showthread.php?t=12716 <=Spicer ESO66-7
http://www.4btswaps.com/forum/showthread.php?14140 <=Aux transmissions-5831-b ratios
http://www.4btswaps.com/forum/showthread.php?25720 <=Hydraulic clutch for Spicer-eso66-7b to 6bt
Miscellaneous General Info:
http://www.4btswaps.com/forum/showthread.php?t=6268 <=Flywheel, using heavier, effects, engineering
http://www.4btswaps.com/forum/showthread.php?t=7173 <=Modifying Russell Conversion fittings
http://www.4btswaps.com/forum/showthread.php?t=8153 <=Dodge hydraulic to ZF
http://www.4btswaps.com/forum/showthread.php?t=10760 <=Mixing & matching master cylinders & slaves
http://www.4btswaps.com/forum/showthread.php?19208 <=More mixing and matching master & slave cylinders
http://www.cjford.stormloader.com/Tech/mantransinfo1.htm <=A lot of good trans info, ratios and such for numerous different transmissions.
http://www.4btswaps.com/forum/showthread.php?3255 <=HOW TO Bleed the slave cylinder
http://www.4btswaps.com/forum/showthread.php?18429 <=Setting Driveline Angles Right!
http://www.4btswaps.com/forum/showthread.php?20444 <=Slave cylinder info
Miscellaneous Info, Auxiliary O.D. Add Ons & Driveshaft:
http://www.4btswaps.com/forum/showthread.php?30913 <=Watson-Transmission-Brown-Lipe-model 45
http://www.4btswaps.com/forum/showthread.php?t=5135
http://www.4btswaps.com/forum/showthread.php?t=6136 <=Driveline angles
http://www2.dana.com/expertforms/depdf.aspx?prod=AXL Dana Axle Manuals
http://www.4btswaps.com/forum/showthread.php?t=9701 <=Aftermarket O.D.'s & problems
http://www.4btswaps.com/forum/showthread.php?14328 <=Adding-an-NP205-Parking-Brake-Option
http://www.4btswaps.com/forum/showthread.php?16052 <=Aligning transmission during installation process
http://www.4btswaps.com/forum/showthread.php?22775 <=How electric transmission speedometer sensors function
http://www.4btswaps.com/forum/showthread.php?38722 <=Ranger-OD Stiff Downshifting
http://www.4btswaps.com/forum/showthread.php?61602 <=Brown-lipe 3-speed auxiliary model-6231 info
NV4500 Exploded Diagram (156 KB)
NP205 Manual (337 KB)
PTO Application Information (37.5 MB)
http://www.4btswaps.com/forum/showthread.php?19343 <=NP205 Explanations & differences
http://www.4btswaps.com/forum/showthread.php?27521 <=47RH VSS testing it to see if it is good
PTO's
NP540:
http://www.4btswaps.com/forum/showthread.php?27721 <=Identification & Application
Awesome information!!! This is what makes this site great!
Posted by Ggg:
Hello Andre
I have some info regarding my GM flywheel I thought should be added to the transmission sticky.
My Cummins reman flywheel specs are as follows;
Casting number 3906802- according to Scott this # does not exist. Written in two places in paint marker is the #3906803- Scott says this is superseded by 3913056 which is what my Cummins dealer said this flywheel is.
Ring gear has 146 teeth
Diameter 14.75-including the ring gear.
thickness 1.973 measured next to the ring gear. The crank mount flange would add about another 1/8" to the overall thickness.
Clutch bolt pattern is a symmetrical 6 bolt pattern.
I hope this is useful.
Gregg (Ggg)
Thank you Gregg!
_______________
Here are the bolt pattern dimensions for the 12V/early 24V Cummins block face:
The above dimensions are in inches - multiply by 25.4 to get the dimensions in millimeters.
Flywheel Housing Adaptor Design Criteria
Digitized with a Romer arm. Looked for design intent. Built Solidworks Models based on intent. The B-Series Cummins is a METRIC engine. Working on pattern design for casting FHZ to adapt Cummins B to Ford ZF using Ford or Dodge starter. The pictured design is the base for any adaptation desired.
Thanks for this thread and all the great info. Any chance someone has the bolt pattern measurements for a common rail cummins? I may design my own ZF6 adapter plate for my project and having the correct measurements would be a huge help.
Mike
The NV T-case link is no longer valid. An updated one is needed.
I originally placed this in the roadranger thread, thought it may be of interest for those with Landcruisers/Nissans and smaller Jap trucks.
They are in Australia and shipping will not be the cheapest but they may have that odd adaptor someone requires.
Cheers Steve
www.dellowconversions.com.au/images/DellowAutomotive.pdf
Link is not found.
Vendor
Both links are working.
Thank you now they are. The only one that isn't working is this one: http://www.newventuregear.com/tcases.html
Its due to the fact that the site was not renewed so it just has random stuff not valid with NV transfer cases.
Since the converted bread van supply is seeming to diminish and more of the box vans that were factory fitted with 4BTs are hitting the market, and have SAE adapters, I thought I'd post up the actual dimensions. This can be helpful to ID as well as build adapters for these Engine plates and flywheels. I would have hit up a mod about putting this into the Stickys but........I'd just as soon not hide info in those indecipherable quagmires.:rolleyes:
(don't try to adjust your screen, the charts lost some clarity when I copied them as pics.)
1 - 20 of 22 Posts
