Perhaps, even though I paid good money for parts and seals.Interesting. Poor quality seals?
I say that because I've have a simular problem with my 46RH (with new seals) with less than an hour of run time on the test stand. It's been constantly wet at the bottom of the bell housing.
you most likely nicked the seal... or warped it when installing.... also check the pump shaft for any burs or nicks..Well, it happened, leaks about 1 (one) quart of trans fluid every five (5) minutes, so I have to drop the trans and figure out what has happened.
Shifts fine when full.
Did you replace the front pump bushing?Perhaps, even though I paid good money for parts and seals.
Yep, the trans leaks around 1+ quarts every 10 minutes...I'm holding off dropping the trans for now, as I have just moved.Did you replace the front pump bushing?
The easiest way to identify the gears sets is the drive tangs. Diesel tangs are more robust.I now suspect, the transmission pump I had installed in my build, has gears for a gas application, my bad because I never really checked the pump internals...when you get old you can get some-timer's, but never ever forget the old ladies name, that is dangerous.
Yes, the diesel version, pumps more fluid at lower RPM, gas version in a known issue in diesel applications...however, I can blame no one but me, if this is the issue...little else would make sense.The easiest way to identify the gears sets is the drive tangs. Diesel tangs are more robust.
