1 - 11 of 11 Posts
What transmissions can I use besides the T-19? Id like to use a NP-435 if I could. Would it bolt up ok? What about bellhousings, as long as it's a small block pattern will it work? Thanks in advance for the help. :)
The 4BT I bought came with a small-block pattern adapter and a NP-435 attached. I can't afford the ZF trans for now so I bolted it right up to the NP-435 already in my F-250. It makes for a very cheap swap.
I use the smallblock ZF but may try to adapt over to an AODE/4R100 or E4OD.
I'm just questioning the length because if It's shorter than the ZF I don't want to be buying a longer driveshaft. I don't mind shortening it.
Ok, stupid question on my part.
Is their a ford big block bell housing adapter for the 4/6bt?
Ford has several engine families classified by most as big blocks. If you're referring to the 385 family, yes there are aftermarket plates.
Not an OEM adapter only aftermarket such as fordcummins.com.
Actually, cummins does make an adapter for the 385 series (460) engine. I have one in my truck. Supposed to get the number for Bob but hospital stay and family death and I forgot until now. No excuse, sorry Bob! I will try to get the numbers and description of install to you. It does require some machining but adapter cost plus machine work was still $100 cheaper than ford-cummins.
Carl
Hey Carl, just post them in this thread and I'll toss it in the index for future reference.
Lakewood Bellhousing
I got to looking and there may be a chance that you could use one of lakewoods steel bellhousing that adapts GM trannies to Ford engines. I am still researching but if it works than you could correct the tilt at the same time. Plus the bellhousing is under $400 bucks which is a lot but if you have misc part it looks like it is much cheaper that buying a whole adapter plate set.
Anybody tried this and I just missed it? Check out their website. I got stuck on hold too long waiting for tech support.
1 - 11 of 11 Posts
