I have a '94 FZJ80, and plan to swap my 4BD2T (still attached to the manual tranny). I need the overdrive, so I have no use for the stock Isuzu manual tranny, but I'll use the bellhousing. My goals for this project are longevity, more power to tow (9K lbs, albeit very rare occasions), and finally increased MPGs for cross country hunting trips. I would like it to be comfortable enough for my wife to enjoy trips in it, but it won't be a DD. I decided to go with a manual because of the increased efficiency and easier/cheaper maintenance, so the NV4500 seemed to be the best choice.
I had planned to use Diesel Tim's adapter, but my challenge is, at the time, no one made an adapter from a NV4500 to my stock T-case (HF2AV). Others have gone to a FJ60 split case, then change out the axle, but the extra work and loosing my ABS doesn't sound appealing. Allmaras recently started making an $800 adapter for the NV4500 to the HF2A T-case, so he's the only game in town. Should I go this route, I'm aware of Dustin's history and the risk. My only hesitation is the NV4500 isn't easy to find and certainly not cheap, then add all of the adapters.
My question: I haven't really consider other options, so I'm not dead set on any of it, including manual vs auto tranny. Are there other feasible options I'm missing? I've read many references to Longbow's configured A440 tranny, though I have quite figured out exactly what this procedure is. Any other suggestions?
