You will find it. Scroll through the performance section. It was my plan (got a lot of scoff from a lot of people) but it can be (has been) done with a single turbo set up by two people that I know of. Problem was it wasnt' driveable. A compound set up should take care of that problem.
Inline pumped version, and low compression pistsons and some head work with the usual pump work and lots of air. The low compression pistons seam to be the trick for at least one of the guys who did it. She is a bit tougher to start though.
