1 - 2 of 2 Posts
Most of this applies to 6B's, but there are many things here that work just the same for the 4B. I will keep this current with more to come.
3900955 Metal expansion plug. (Little plug that fills in the little hole in the block, where the old dipstick went, front sump v.s. rear sump.) All years.
3928740 Oil dipstick. 12 & 24 valve.
3905801 Oil dipstick tube. (Plastic.) 12 & 24 valve.
3280885 Oil gage metal. (The metal piece that is in-between the plastic dipstick tube and the block.) 12 & 24 valve.
4089093 Oil pan. (Aluiminum, the least expensive replacement pan.) 1994-1998. 12 valve, fits 1989-2002 engines.
3938455 Oil pickup/suction tube. 12 & 24 valve same as oil pan.
3914383 Pick-up tube gasket. All years.
3926910 Oil pan plug. 12 & 24 valve.
3902425 Oil pan copper washer. 12 & 24 valve.
3902605 Valve cover w/plug. (Changes from the Dodge style oil filler area.) All 12 valve engines. 1989-1998.
3903463 Access cover plug. (Covers the hole where the Dodge style oil filler neck was.) All 12 valve engines. 1988-1998.
3939258 Lift pump gasket. 12 &24 valve.
3969988 Air intake gaskets. For 2003-2006 24 common rail, will work on 12 valve.
3920779 Short head bolts. (X6) All 12 valve engines.
3920780 Long head bolts. (X14) All 12 valve engines.
4089648 Complete upper gasket kit. 1994-1998. 12 valve.
3802376 Complete lower gasket kit. 1994-1998. 12 valve.
3911660 Fan hub kit. (EXPENSIVE little kit.) 1994-1998. 12 valve.
3911668 Fan drive to hub bolts. (X6) 1994-1998. 12 valve.
3902114 Fan hub to block bolts. (X4) 1994-1998. 12 valve.
3931744 Cummins 12 valve exhaust manifold. Turbo outlet pointing straight down between #5 & #6 cylinder (for much better air box clearence-tighter to the engine)
3973422 Heres another manifold that also has the port outlet straight down, but this one has the outlet in the center of the manifold, between #3 & #4 cylinder.
I copied this into the Main Menu FAQ Thread for future references. ;)
1 - 2 of 2 Posts
