v6 tdi?
25K views 37 replies 13 participants last post by  00quattro00
#1 ·
has anybody swapped one? do the have the same trans pattern as the 4cyl? would they offer a better platform for a dd/trail rig/mild towing(85 4runner will be running dual cases,5.39. and 38's)
#2 ·
really seems more suitable for the application you're considering... as far as i remember, the bolt pattern is not so much different, if it has any difference at all... one good thing from volkswagen is the modularity and interchangeability of its engines...
#8 ·
Yes. Completely different.
Over twice the torque, about twice the power.
Commonrail injection instead of the PD of the 1.9.
Much more advanced and integrated computer control.
It was never sold in the US. So expertise may be hard to find nearby.
#12 ·
I would love to use one to replace the wifes 2.8l gasser in our A-6 Avant.
A Diesel powered AWD wagon would fit the bill perfectly.
instead I will be most likely trading it for a FWD Jetta TDI sometime soon.
that swap would be difficult enough, and the engine came in that body elsewhere in the world.
I would love to see you do this, but it is going to take some major pioneering/engineering on your part. Just make sure to evaluate this can o worms before you dive in.
#18 ·
It'll be more economical than any comparable petrol. The vehicles with those V6 tdi's in are generally larger and would use similar fuel to a smaller economy petrol car.
Some fuelly stats:
A4 3.0tdi (this is a very fast car, likely driven pretty hard) http://www.fuelly.com/driver/daggerit/a4-quattro
A6 3.0tdi, this is a quite big and heavy car, also likely driven hard. http://www.fuelly.com/driver/gupsterg/a6-quattro
I wouldn't expect to get better than 7 litres/100km with one of these engines. But it will be a complete hoot to drive in almost anything.
here is a picture of me driving one*.
*Some of the cars that day were petrol v6, others diesel v6, I'm not sure which one is in that photo. Car is RHD.
#26 · (Edited)
Hi guys.. I bought a 2014 Passat TDI last year and it has exceeded all my expectations. After one year of driving it We have it settled into averaging 41 MPG per each tank full. This is combined local and freeway driving. On the road to and from Las Vegas I am seeing 44 at 80mph on CC.
Last time I came home I drafted a Suburban for 70+ miles across the desert from state line to outside of Barstow. It got 48.6 MPG on that trip home and it cost me $21 in fuel. 7 gallons for 340 miles. Not bad!
The car has 140hp but is a torque motor, and if you drive it that way (no need to exceed 3500rpms) it delivers excellent performance.
The 6 speed gearbox is easily controlled with your throttle foot, and you can row thru the gears easily. It is running 2200rpms at 80 mph and cruises effortlessly at 80-90 mph. Passing times are quick as there is a gear for everything. Punching it in bottom gear yields a nice turbo lag and then wheel spin from hell. Best to come out of the hole easy and as soon as it picks up 2nd you roll the throttle into it and away you go,,, the 20 to 50 time is about 2.5 seconds. Getting on the freeway is all about 2,3,and 4th gears and you're doing 80 mph with two subsequent upshifts to the stacked OD's. This car doesn't even feel like it is moving below 80 mph and if you don't look at the speedo, that's where you end up. 65-70 is ole lady speed.
There is absolutely no reason to take this engine to 4K rpms. You do it all with midrange torque and the gearbox.
This car is an absolute joy to drive on trips. Oh, a Passat is a North African Wind. It seems that VW marketing is obsessed with North Africa.
I have an older German guy I have breakfast with at McDonalds frequently, he was part of the VW Engineering Department, and did testing on all the cars here in the US up til 2005. He is extremely intelligent.
Two weeks ago I bought a 2015 Touareg. Touareg's are North African Goat Herders or something like that.
This car has the 3.0 V6 Diesel engine and an 8 sp Gearbox. It is still learning how I drive , and I am still learning how to drive it smoothly.
The power on this one is considerably more than the I 4 in the Passat. It is 240HP and over 400ftlbs. It is more powerful than the Cummins B 5.9 in my 95 Dodge Truck by a considerable margin and half the size.
The gearbox I'm still learning, but bottom gear is nearly useless as it's all done about 20mph, 2nd gear doesn't last long either, but 3rd is where you roll the power in and then 4th you're at 80 mph waiting for 3 more shifts down to 2K rpms at 80mph. The gears are about 250 revs apart which is exactly what you'd expect with 8 gears
This car is much faster than the Passat and the Passat is by no means sluggish or slow. This engine wants to rev a little higher but like the I4 there is little need as the midrange is where all the power is all at.
I had been trying to figure out how this body compared to the Audi Q5 or Q7. My friend told me it was not part of that line. The Touareg is a Porsche Cayenne with a different front clip and a different engine. It is easy to see when you see them side by side.
So far I'm loving this car. It is a lot more car than the Passat and was also $20K more . Much smoother on the road, but since it is a heavier car the fuel mileage is not going to be comparable to the Passat. So far with only 900 miles on it I'm seeing 26-27mpg combined. I'm taking it to Las Vegas in a couple of weeks, so we'll see what it will do on the road. I expect over 30MPG which for the size of the car is quite acceptable.
If we got Audi A4 wagons with Diesels here in the US, I would have bought one. If we got A6 wagons with diesels I would have bought one. We don't get either? Why?
I have no idea. Marketing departments run on a different type of logic than the rest of the world.
I now have two new VW diesel cars and I really like both of them. Both of the MBZ's went down the road to new owners. Still have my Dodge, the DeScrambler, and my CJ5
Now The only gasoline car I have is my CJ 5 which hasn't ran in 8+ years. I'm fully dieselized. Just hope they don't stop making the fuel. My wife would hate me if she had to drive the CJ5!
Randy
#33 ·
Apparently Q5's showed up in the states with a diesel option in 2014 - I've never seen so many engine options...
From Edmunds:
The 2014 Audi Q5 2.0T comes standard with all-wheel drive and a turbocharged 2.0-liter inline four-cylinder engine good for 220 horsepower and 258 pound-feet of torque. An eight-speed automatic transmission is standard. EPA-estimated fuel economy is 23 mpg combined (20 city/28 highway). In Edmunds testing, a Q5 2.0T accelerated to 60 mph in 6.7 seconds, a performance on par with the Audi's peers.
The Audi Q5 3.0T gets a supercharged 3.0-liter V6 that produces 272 hp and 295 lb-ft of torque. An eight-speed automatic is standard, as is an automatic stop-start system that saves fuel by shutting off the engine when the car comes to a halt. In Edmunds testing, the 3.0T engine brought the Q5 from zero to 60 in 5.8 seconds, a very quick time for this class of vehicle. Fuel economy estimates stand at 21 mpg combined (18 mpg city/26 mpg highway).
The Q5 3.0 TDI features a 3.0-liter turbocharged diesel V6 with 240 hp and a massive 428 lb-ft of torque. The automatic stop-start system is standard. Audi claims a zero-to-60-mph time of 6.5 seconds while fuel economy estimates stand at 27 mpg combined (24 mpg city/31 mpg highway).
The Q5 Hybrid pairs the 2.0T's engine with an electric motor and battery pack to provide a total output of 245 hp and 354 lb-ft of torque. Audi estimates its 0-60 time at 6.8 seconds, while EPA fuel mileage estimates stand at 26 mpg combined (24 mpg city/30 mpg highway).
#35 ·
anything came of this SWAP?
I ran into a guy on a different forum bring out a stand alone Ecu for Diesel common rail engines
presently shipping and does "SOLONOID" injectors and he is working on "PIZO" injector version for the NEW year
I assume this engine is a PIZO style
if this works like petrol stand alone imagine all the swaps this opens up
#37 ·
The 3.0 and even 4.2 v8 tdi were used for a brief period by mercriser as inboard diesels. Stupid power to weight ratio. The 3.0 was rated up to 260 and 4.2 up to 370 iirc. They used a stand alone computer and ive read where owners used vag-com for diagnostics. Contact Malone or tdi tuning or i think its rocket chips for info on tuning the ecu to stand alone. VW pulled out of the marine contract but so did cummins a few years before that( marine business with mercrusier that is) they have not been able to keep diesel partners long.
They are very economical. The toaureg (sp?) Got killer economy for a full sized awd suv and in Europe got the v8 4.2 which we only got in marine form over her in the states.
Im also trying to find out if the 3.0 is the same bolt pattern as the 4 cyl engines and the non vr4 v6 gas motors.
