OK, I know there is alot of info I've read on this forum on this but need to pick a little deeper.
Found this old thread CPL VE timing specs with great info on CPL# and settings for plunger but still a little concerned about my setting.
I have a 1985 engine 94hp @ 2200rpm with CPL 592 and timing on data plate stating 2.0mm plunger timing which also lines up with the other data I found in the link above. Had the local 'tuner' work on it and apparently 'timed' the pump but bumped it a bit.... from what it was when I bought it(? unknown), to what he bumped it to was questionable until I measured with dial gauge. Was measuring at 1.7mm on the dial gauge that he'd bumped up to.
Seemed to run a more smokey (especially on start up/cold) with EGT's climbing rapidly under acceleration compared to where it was at 'pre-tune'. See pics below of piston tops when I removed the head. Note; cleaned up there was no signs of melting spots which was a good thing.
Having pulled the engine out to re-seal oil leaks and re-do leaking head gasket(needed the new DCEC head decked to get true flatness) and also have it O ringed, I don't want to risk getting this wrong.
Back story on the engine if it helps, VE pump with 3200 spring and fuel pin, std rebuilt bosch injectors, 60lb valve spring, ported exhaust ports and port matched exhaust manifold, stage 2 colt cam and going to be running a new HX30 Super.
So, with all that said and done, my concern is that if the pistons looked like this when pump was set at 1.7mm, thinking it will be worse again pushing it up to 2.0mm as per data plate. Thoughts and advice??
