I would also like to know this.
I'm trying to tie my cruise into the tach so I can idle the truck up. The cruise doesn't work until 35 mph, so that is going to be alot of pulses.
What are you trying to do with the Vss Tmi_13?
OOPs, just saw you had a chevy, I'm sure they're different from the fords.
How would it respond without Vss input???hardwire the cruise, it should just be a vacuum actuated servo. There should be two solenoids, one to increase vacuum (throttle up) and one to decrease vacuum (throttle down) This is my understanding of a dodge unit, but i would expect others to be similar. you can have a momentary toggle to raise and lower the throttle in small increments.
if it were truly hardwired, it wouldn't care. i've seen people use it as a "thumb throttle" for offroad vehicles for winching.How would it respond without Vss input???
I was also thinking that I have a little signal generator that goes right in the speedometer cable. It was part of some very early emissions on a 71 or 72 F-100 and was bolted to the ds inner fender. The cable screws in both sides and 2 wires come out the side. I am not sure the frequency but it is no doubt just a square type sine wave like a hall effect or similiar.
The cruise control servo on my truck is all electronic. It has the throttle cable coming out of it and about 7 wires going into it. Any ideas for idling it up that way??hardwire the cruise, it should just be a vacuum actuated servo. There should be two solenoids, one to increase vacuum (throttle up) and one to decrease vacuum (throttle down) This is my understanding of a dodge unit, but i would expect others to be similar. you can have a momentary toggle to raise and lower the throttle in small increments.
I highly doubt that it'd operate very well.The cruise control servo on my truck is all electronic. It has the throttle cable coming out of it and about 7 wires going into it. Any ideas for idling it up that way??
I dont have speedo meter cable connection anywere, but just ordered speed sensor and signal adjuster from dakota digital, that goes on drive shaft. Will see if that works.
Hey do you have any pics of your Samurai suspention? or more pics? lolDid the signal adjuster from Dakota Digital work? What type of speed sensor did you order? I am trying to hook up the cruise and a dodge speedometer in my Chevrolet crew cab.
Sorry i haven been able to write here in a while. but i´m back. Yes it did work the computer now sees speed signal, but unfortunately by tranny still does NOT shift gears. I´m getting little frustrated.Did the signal adjuster from Dakota Digital work? What type of speed sensor did you order? I am trying to hook up the cruise and a dodge speedometer in my Chevrolet crew cab.
