1 - 4 of 4 Posts
Need fittings and associated lines for round oil cooler, right side of engine, fittings are on bottom side of cooler. Didn’t pull my engine, came with none.
Ed in CO.
Ed, don't have those parts but might help some with the numbers. Below is a diagram of all the parts. Some of these you may already have. Probably looking at a couple hundred dollars in parts. So here goes.
2 3914823 oil cooler line (1 required)
3 3931545 hose clamp (8 required)
4 3916285 oil cooler line (1 required)
5 3931521 elbow hose (3 required)
6 3931522 plain hose (1 required)
9 3923086 tube brace (1 required)
10 3923087 tube brace (1 required)
11 3923103 hose coupling (1 required)
13 3925883 M8x1.25x16mm bolt (4 required)
If you had to buy them new they are kind of pricey. The one that is kind of crazy is the #11 which is about $30. The long ones are about $80 and $50 each, give or take a little.
1 - 4 of 4 Posts
