1 - 7 of 7 Posts
Many members have used the Ford/Freightliner high mount ac bracket. It's especially useful on GM vehicles because it get the ac compressor away from the frame and the need to notch for it. However, the water inlet that is normal for that bracket points straight down and the frame rears its ugly head again. You can't point it forward because the tensioner is there. The usual solution is to fabricate an inlet coming straight out like the one in Rube Bonet's build pictured below. I always wondered if Cummins might have such a creature in their parts bin and sure enough I found it. It's part # 3941929 and is designed for 2" hose. Looks identical to the one Rube fabricated. Thought this might be of use to some of you guys.
Those had been on ebay for months and no one show any interest. I wasn't absolutely positive is was correct but took the chance and I was right. I believe it is off a QSB 4.5/6.7. Cummins isn't big on changing bolt patterns on things even between engines.
1 - 7 of 7 Posts
