You like creating problems for youself. If you had an accurate gauge you would know the condition of the pump. Testing is always better than guessing. What was the inlet filter on the LP like?
I got my accurate gauge yesterday and it indicates the same thing as the inaccurate gauge. (a vacuum when running) I didn’t take the inlet filter out. Is it just a screen? It would appear that it can pump scrap oil easily, so I doubt it is clogged.You like creating problems for youself. If you had an accurate gauge you would know the condition of the pump. Testing is always better than guessing. What was the inlet filter on the LP like?
It’s kind of hard to check that screen because I pumped scrap oil through it. (It did pump easy though)Yeah, sounds like a multitude of problems and all associated with the lift pump. Be sure an put the correct filter on with the new one. Might inspect the input filter screen on the old lift pump a see if any trash had collected there. If so you might have gotten some bad fuel. Happened to a friend of mine. We were traveling together on vacation. My truck was diesel his gas. We fueled up at the same time, but at two different stations. We drove about a mile and his died right in the middle of the interstate. We got him towed to a shop and they found muddy water in his gas tank. Stuff like that does happen.
If the lift pump couldn’t suck through the inline filter enough to make any pressure, how could the injection pump suck enough to run?Did you say that you have an in-line filter before the pump? If so, I would give that a look, Very difficult for the pump to draw through a filter.
Tank is all brand new stainless. (I welded it up) Fuel lines are all stainless hard lines except for about 6” of flex at the motor. Tank has a pick up tube. The vent line goes to one of those little cone air filters Tucked up inside the body. I happened to be in the access panel right before this trip and it looked brand new. I have the gauge on the outlet side of the filter. So if that filter was clogged, it could be the whole problem.OK, if the pump does pump and you have vacuum showing then you have a restriction in the system. What do you have for fuel lines? Tank pick up? Side mounted, sump or pick up tube? Tank vent? Which banjo bolt is the gauge on?
Not slant cut, but when it was giving me trouble, I still had 15 gallons. Also, my tank design has a 5 gallon drop out where the pickup and float go. That section of tank is very sturdy.Is the pick up tube angle cut at the inlet? Have seen straight cut tubes that grab the bottom of the tank when low on fuel.
I got this motor from longtime member on here. Something like “crucab deisel” in TN. He said he got it right from a truck scrapper. He seemed to be a “straight arrow“ kind of guy. I don’t believe he would lie to me. Of course, anyone could have changed out the filter before he got it.That FF42000 filter you had on there would not likely have been used on a bread truck. That is a special filter only used on the dual filter setup which not used on road engines. Now the previous owner could have stuck that on there but the engine specifies one with a water separator. That filter could be used on other brands of engines but wasn't specified on the 4bt.
When one mounts the pump, one is compressing the spring, surface is slanted, hard to reach and see. Studs provide guided route to start with, much easier to start nuts when unit already guided by studs, not have to hold against the spring, find threaded, off angle hole with bolts.
Everyone’s choice, for $10. worth it to me!
You left out the bit about the gaskets and spacer sitting on the studs instead of trying to
keep them all together on the bolts.
Ed in CO
