SO I think I got me a 12 valve that needs to be pulled apart and built up. I dont want to do anything crazy, just try and get it running again. I guess it melted the turbo so I need to get in and check out the pistons. I have been hearing about the different injection pumps and cannot get a visual picture of what they look like. He said it was one of the last 12 valves so is that a later 90s? I could mnaybe get a 24 valve, but id rather stick with the 12 valve because of wiring.
If its a 89-93 engine it will have a ve pump on it, if its a 94-98 it will be a p7100, I've heard them referred to as the million mile pump because they just last that long, depends on what it came from as to how much power it has in stock form, but that doesnt really matter with a little tuning, the auto trucks had 10 or so less hp than the manual trucks did and the horsepower rating jumped a little after the 94 & 95 models, so a 96 97 or early 98 truck with a manual trans has 215 stock hp compared to the earlier 190hp. Any 6bt cummins you need can be found at
www.dieseltruckresource.com , theres a lot of real good guys on there that would be more than happy to help you out. Stick with a 94-98 12v they are by far the best, they are reliable, cheap to work on, and can be turned up for very cheap, I drive one everyday and love it. Stay away from the 24v's they have a vp44 electronic injection pump that is prone to problems due to poor lift pump fuel pressures and costs over $1000 to replace it, they are also more $$$$$ to do power modifications to.
