not yet thats tomorrows projectbounceCool little oil fill there...hadnt seen one like that. No ps pump yet?![]()
Damn i have these sensors every where what is the sensor on top of the water outlet right by the thermastat and then i have another one under the water inlet and then another oil pressure gauge buy the oil filter i am going crazy:rasta: also they were linked togeather also do you know what the sensor is off of the pumpTop right is water temp and the bottom one is oil pressure.
On the Dodge 6BT there is two sensors exactly like you have in the picture. There is also an intake air temp sensor in the head over the fuel filter, this sensor works together with the KSB (cold start device).Damn i have these sensors every where what is the sensor on top of the water outlet right by the thermastat and then i have another one under the water inlet and then another oil pressure gauge buy the oil filter i am going crazy:rasta:
Mine had lots of extra sensors on it as well. The truck that I pulled mine from had a dash mounted warning system for oil pressure and water temp, I'm guessing that is what all the extras were for. I just left the senders/sensors in place to plug the holes but none of them are plugged into anything.Damn i have these sensors every where what is the sensor on top of the water outlet right by the thermastat and then i have another one under the water inlet and then another oil pressure gauge buy the oil filter i am going crazy:rasta: also they were linked togeather also do you know what the sensor is off of the pump
