1 - 20 of 23 Posts
There can be 300 degrees difference across a turbo!! Best to stay below 900!
What you want to see is pre-turbo temps. 1300 for very long--30 seconds- can be bad.
aluminum melts about 1275 but it takes some time at that temp.
you are readding the temp post turbo!!
Many different things can cause high EGT.
1.To much fuel.
2.Needs more air ,or cooler air ( intercooler)
3.Better Exhaust .
4.bigger turbo .
5.timming.
The EGT probe needs to be pre turbo to have the right temp.
Scott
The probe needs to go into the exhaust manifold right before the flange for the turbo, say about 1.5 inches up from the flange or so. A pyro after the turbo is worthless, too many variables for incorrent EGT readings.
Like this
i'm also a bit interested in this thread. i was under the impression if i stayed under 550 deg. c. it would be ok. does this sound right ?
This is what I remember reading: It's usually best to have it in the runner that is connected to #1 cylinder. The first cylinder has the most restriction, therefore it runs the richest and hottest.
Well you will see that 90 percent of all pyro probes are in the back. I have mine in the 1,2,3 runner on my 6bt for that very reason. Just about every hood I pop to do pump work on will have the prob in 4,5,6. Whichever I guess. The cummins can withstand a constant 1200 degrees without any trouble, sustaining 1500+ for any length of time is not recommended. :nuke:
Discussion Starter #14
Which turbo do you reccomend. Take a look at my pics I do not know if I can fit a bigger one. Very close to the oil filter relocation kit. Right now running a stock h1c. If it comes down to it I guess that I can drive down to knoxville and let you take a look lol
You can get one off any 89-98 dodge 12 valve and cut the outside cylinders off.
Upgrading your turbo to move more air does not mean getting a physically larger turbo. You can put a smaller turbine housing on your H1C and get a lot more pressure out of it.
That exhaust manifold is off of a 6bt 12 valve cummins. Hot Dawg cut 1 and 6 off of it and welded the ends up. Its a pretty common swap on the 4bts.
Does anyone know where i can get a exhust manifold like the pic from dennyt above
I am using a 14cm3 exhaust housing with a 54mm compressor wheel. I also have made changes to my mounting of the alternator and A/C compressor. When I did my upgrade on the turbo the inlet of the turbo went from a 3" to a 4" and space was very limited. I will take some pictures tomorrow of the upgrade.
I've been running my Isuzu regularly up to 750 deg C, it seems to survive okay. The occasional (accidental) excursion past 800 too.:puke:
Post turbo is a guessing game, shift the probe if you can.
actually #6 is the most common cylinder to melt in a 12v and a 24 the later common rails like to eat #5 first them #6. though #1 has restictions the rear ward cylinders are the furthest from the air flow. i have run pyros on the front 3 and rear 3 on a 6 cyl as well as individual cylinders for testing on the 6cyl #6 ran the hotest #1 was the 3rd warmest. on the 4Bt things are a little more even but the rear cylinder is always 50-75 * warmer. i assume water flow may also influence this?
1 - 20 of 23 Posts
