What is this on the FI pump?
Mine doesn't have this:
I don't know, I think CPL 858 but not sure. Tag is gone.what's the CPL of your engine? That vaguely looks like an inline pump engine to me.
That is all you are going to offer? What the hell does KSB stand for?That there is what they call a KSB
the ksb is the wax motor. It helps with cold start. There is a cummins service doc in the yahoo group that has a lot of information on it.I don't know, I think CPL 858 but not sure. Tag is gone.
That picture is NOT my engine, it is "averageF250".
Mine doesn't have that.
Should I find one for my engine?
What does it do? What does the wire do?
Post 3 said what it does !I don't know, I think CPL 858 but not sure. Tag is gone.
It is an acronym for the cold start device thingy with the German name you already got the answers for. If I find it again I'll post it up...What the hell does KSB stand for?
haha, thanks! the search does need some work...Diesel Durango you are much better than that darn ol search button! :happyfinger:
Exactly. I wouldn't run it long without power to it on a non-intercooled pump. This is the setup I have running on mine.On the wax motor type you can run a lead from the run side of the shut off solenoid directly to the wax motor terminal. This is what the non intercooled Dodge guys do whenever the temperature switch that controls the wax motor fails.
LincTex;11309) That is all you are going to offer? What the hell does KSB stand for? Should I find one for my engine? What does it do? What does the wire do?[/QUOTE said:If jackasses used the search function here you'd probably save a lot of people from getting carple tunnel. If you punch KSB in, you'd see 50 threads or posts stating the same F***ing thing.:happyfinger:
How far did your blood pressure rise while typing?If you punch KSB in, you'd see 50 threads or posts stating the same F***ing thing.:happyfinger:
None, just annoyed. If you dont know what your CPL is, punch in your engine serial #( on back of motor below head(use mirror,if you can read backwards)) on Cummins quickserve(no money for one serial #) and they will give you all options for your motor and the cpl(I think). They told me all original parts on my motor and updated part #'s. Practice spleh siht epoh.How far did your blood pressure rise while typing?
