1 - 5 of 5 Posts
I am in the market to purchasing a new lift pump I think that the diaphram in mine has a hole in it. witch pump is the best one and where can I track one down thanks in advance
HALFBREED:)
The Dodge first generation guys have given good reports on this replacement $40 version from: http://www.usdieselparts.com/moreinfo.cfm/Product_ID/57177/sku/FP274/name/Feed_Pump
The next option is going to your local auto parts store or Dodge parts department and buy one for an 89 - 93 Dodge with the Cummins diesel.
The third option direct from Cummins is probably the most expensive but is compatible with running WVO:
Fuel pump installation parts, low pressure piston type for use with Bosch VE Pump:
  • Cummins Part # 3936320 lift pump (qty 1 )
  • # 3914753 Fuel Line (qty 1)
  • # 3931348 Gasket (qty 2)
  • # 3918191 Seals (qty 2)
  • # 3914284 Spacer (qty1)
will the dodge pump fit all the fitings that my lift pump has or will i have to get adapters.
The fittings and their positions on the diaphragm type pumps look 99.9999% identical to me.
What about Bio-Diesel? Or is that something I have to figure out on my own? :tongue:
1 - 5 of 5 Posts
