Well I'm starting in on my 4BTA and was wondering what the 3 pin sensor/ connection is that is mounted on the bottom of the intake manifold. it's underneath and kind of recessed (oval shaped).
You are most likly refering to the KSB Sensor. Two types of KSB actuaction has been used, and both require different senors.Well I'm starting in on my 4BTA and was wondering what the 3 pin sensor/ connection is that is mounted on the bottom of the intake manifold. it's underneath and kind of recessed (oval shaped).
Treetopflyer;CJ8: That is indeed the location and appearence of what I'm refering to.
Paul: "KSB" & "WAX MOTOR" are beyond my scope. I got an idea of what they are by the follow-on posts...any other references so I can learn more about that aspect of the engine? There are only 3 sensors I can find, one on the thermostat housing top front passenger side (H20 temp.), another mid-driver side of the block (oil press. I believe) and the third as described in the thread subject.....any others? Thanks guys
I uploaded the KSB info to my Image Event Site. Go to the link and double click on each picture for a full screen. You can also right click and save and blow up even larger on your onw computer. This is from the Cummins Shop Manual.Treetopflyer;
The KSB has been discussed here before. Do a search to save me typing. IF you cant find it, I will post again. Thanks, saves my fat fingers pounding on the keys ha ha. The only source I know of for KSB info is the Cummins Shop Manual.
Paul
