Splines are right, as well as bolt pattern, seal diameter is right too, but when case is about 3/16ths" from mating the housing of the NP208 bottoms out where the seal is pressed into the 47RH, it looks like a spacer would solve the problem, does such a thing exist?
Or perhaps I should just go with another t-case. I tried a 242D from a Durango I have laying around, wont work, bolts up but output seal in 47RH does not reach machined surface on 242D.
Any ideas,
Thanks,
John
Any ideas,
Thanks,
John
