Hi, im new here and have alot of questions. first my truck 90 chevy crew cab 4x4, 373 gears 33x12.5x16 tires th400 trans blown up 6.5 non turbo with low milage on motor(someone droped air cleaner stud down intake before I bought it). What I have for a motor is a 89 5.9 out of a passenger bus with a 545 allison attached to it I also have a 4bt with a chevy bellhousing adapter on it. Is the adapter the same 4bt to 6bt?
I would rather use allison but dont want to go to divorced t-case and 8 foot front shaft. is A flex plate available to mate to a th400 (the 4bt is a stick)I think it would be much easier to use what is in the truck.the 4bt is in a chevy chassis now, might the motor mounts work? any info would be great. thank you.
