I use Mahle open bowl 4BT/non-IC 12v pistons in all my builds, but I relieve the aluminum portion of the top ring land.
I do not recommend anyone use those pistons without relieving them. Every single used set I've removed has had distorted/scuffed upper ring lands.
They are a great piston. Open bowl/low ring design makes them efficient and resilient, but I don't think Cummins knew the upper land would expand so much. All subsequent piston designs had a relieved upper land, but they also had the ring pack much higher as well.
There's a common industrial piston with the same bowl design, relieved top land, but the ring pack is high like the rest. I'm sure they would work fine for most, but I prefer the non-IC pistons for my builds. Atleast to me, the 155 degree bowls seem to make more power for a given fuel rate/timing compared to closed bowl. They also work fine with common/cheap 155 degree marine nozzles.
