I have a 4BTA- CAC, CPL 1260 that someone before me has changed the Turbo. The turbo has a 4 Inch air intake and 3 inch out to manifold. The following info is on the Turbo Tag;
Assembly 3533320
Serial C028268
Customer 3925740-0-08/3
WH1C
There is no visible wastegate
The Bosch IP appears to be stock as the factory caps are still on the adjustments. Its obvious someone did some work prior to bolting on this turbo, The Turbo and Manifold have been bead blasted, new gaskets and bolts on the manifold and manifold/turbo and a new high pressure oil line to the turbo.
Any idea why this turbo may have been put used, what performance gains could be expected. ON the test stand, this engine runs great.
Is it good on this engine in a stock configuration, or should I change it back to a H1C.
Paul
Assembly 3533320
Serial C028268
WH1C
Paul
