Not a 4bt question but looking for some insight from you experiened diesel heads. My wife put 26 gallons of regular gasoline in the 6.5td suburban while I was at the bank nearby. The pump shut off because it had reached $75. I added 6 more gallons of diesel. It ran rough and low powered over to Wal Mart where I added a quart of ATF. It wouldn't start so I dumped in a quart of Power Service. We let it sit for about 2 hours while we walked over to look at a 6.2 K10 we had been scheduled to see. When we came back it started and we drove it the 10 miles home with a 2000 ft. climb at speeds of 35 mph max. I would run decent up to about 1500 rpm and it idled nicely. What should I do now? Would it not run well because of the low cetane in gas? Should I dump in one or two more quarts of Power Service? Or do I have to drain that fuel mixture out? I was thinking maybe I could drain half of it and fill the other half back with diesel then poor it back in over time. But I'd like to avoid that unpleasant task if possible.
Brian
Brian
