1 - 20 of 21 Posts
Will aftermarket injectors lower my egts?
If so, how and why?
Will the PODs fit my engine?
(damn I wish I could see my engine tag) My engine is a 4BTA, a rotary pump version with the air to air aftercooler. I hope that helps.
Bigger injectors will make more power and raise EGT usually, every thing else being the same, ie. timing, turbo,etc. More fuel charge, bigger bang, higher cylinder pressure, higher temp.
You might check on the fact that most of the after market injectors that have high outputs also require high output pumps. PDR told me I could use the 190's but indicated they work better on the newer higher pressure pumps. PODs may also like a higher pressure pump. Might be worth searching all the other forums. Not much sense in spending good money on something you cannot make work much better than the stock parts. Anyone have the PODs in their 4BT?
interesting, I have noticed that everywhere I look for aftermarket injectors they claim a reduction in egts. Dirty crooks.
Yeah, I never could figure that one out myself!? Next they'll be saying you get better mileage too!
I guess you could get to a point where the injectors are maxed out for a certain boost level with high EGT and by putting bigger injectors in the additional fuel helps quench the burn and lower the EGT for the same boost level but then you've got lots of smoke. I think that's what the pullers do, they look like a coal fired steam locomotive pulling a grade. Fuel economy is not one of their priorities.:)
Not Useful Information
Aftermarket Injectors can lower egt's at a given HP level. It is doubtfull they will lower egt's at WFO but can. They also can increase fuel mileage during nomal driving but definately not at WFO. If you are blowing smoke you are running rich and therefore hot, and wasting fuel. Aftermarket injector builders do alot of R&D with alot of dyno time. They get a better spray pattern from stagering spray angles and adding more holes to the tip. They dont just hog out a stock tip anymore. They start from scratch. I like EDM injectors. All of my experience is on my 2002 Dodge not a 4BT. I have run several sets of injectors and set ups on it. I currently get 18-20 mpg with a 7500 lb truck on 35's. I dynoed with 444HP/978TQ and drive the kids around with it everyday!:)
My 4BT will get a set of EDM's along with a upgrated turbo some day. First I got to get this thing in and going! Do some research and talk to some builders about what you want out of an injector. You want a more effiecient burn out of your fuel not just smoke.
I highly doubt aftermarket injector builders can do a better job than the factory suppliers.
There's no comparing the R&D budget of a small aftermarket company with engine manufacturers and their OEM supplier.
Engine makers compete on BSFC. If there was a fuel consumption improvement to have then they would have it.
If you cannot get enough fuel for a given power out in time, you will still be injecting fuel late in the stroke and just basically putting fuel into the exhaust manifold. This is one area where nearly any injector nozzle work can beat the OEM design. They actually have to be less efficient at flame front propogation in some instances in order to meet certain emissions requirements. I don't.
That is not true at all.
Fuel and the fuel lines don't have an appreciable amount of compressibility in them, when the pump (or unit injector or commonrail injector) stops applying pressure the fuel flow stops.
You do not get fuel injected later into the exhaust manifold.
Talk of MPG isn't proof of any upgrade. Get some BSFC numbers if you need to back up fuel economy claims.
Discussion Starter · #15 ·
428rwhp 180mm^3 per shot of number 2 diesel fuel. That's pretty clear to me. I have NEVER seen a stock injector make more than 300rwhp in person, and only ever heard of 340rwhp. (This is a 7.3L powerstroke)
The title of the thread isn't "will aftermarket injectors make more power".
And it is 100% correct that time to empty is paramount. And yes, the OEM nozzles WILL be spraying late on the stroke attempting to accomplish the same task as the Extrude Honed ones I run, 100% chance.
For a stock nozzle to empty my injector it takes over 5ms, and they still aren't empty. In 4ms they will clear 180mm^3. Whereas my nozzles will 100% empty 250mm^3 in LESS than 4ms. So if you plan to empty my injectors (250mm^3) you'd better have something other than a stock nozzle on it (considering 4ms at 3k rpm is getting pretty dang late in the stroke)
Again, I call BS. If your injectors are emptying sooner, then the injection pressure is much less, the droplet size is bigger and the burn is slower. None of these things are good for EGT's or fuel consumption.
If you have evidence, post it. Another two pages of dribble won't convince me.
I can produce 140% OEM output with no smoke and lower exhaust gas temperature than the OEM injector is producing at the lower power output.
Doesn't prove your point, I can lower my EGT's simply by pushing up boost. It doesn't mean my injectors have improved.
First of all, how does 428hp on 180mm^3 of fuel not mean better BSFC? I have never seen stock injectors make more than 300 in person and 340 I have only heard about The truck that made the 340 is running my exact same turbo, and more timing than me. Stock injectors inject ~150-155mm^3 of fuel per shot at full stroke.
428rwhp divided by 180mm^3 yields 2.37hp per cubic millimeter injected.
340rwhp divided by 150mm^3 yields 2.26hp per cubic millimeter injected.
Droplet size is bigger.......from and orifice of .006" to something LESS than .007" I don't think you can tell me that will effect droplet size, or more correctly, the surface area to volume ratio of the droplets a discernable amount. Injection pressure remains the same, it is not a fixed flow through the nozzle, it is a fixed pressure (assuming flow rates through other parts of the injector are not exceeded).
These are unit injectors. HEUI. Hydraulic Electronic Unit Injection. As long as flow is maintained throughout the hydraulic circuits within the injector, nozzle enlargements do not drop injection pressure. And I will assure you, that a change of less than 1 thousandth of an inch does not drop IP.
BSFC is calculated from measured values. Not by basing assumptions off what your injectors are theoretically supposed to do.
Stock 4BT gets close to 200 g/kwH, similar BSFC to the current crop of hi-tech diesels from mercedes and VW.
Come back when you've got some real data.
I also assumed that the horsepower output from a Dynojet 248 could be used. This is from having made pulls on it with periods exceeding 3 months at a time and the output from one such series of pulls was 402.4, 402.1 and 402.3...... with nearly a month between each pull.
You'll have to excuse me for assuming that to be an accurate device.
Does the dyno have the ability to measure fuel consumption at steady load?
If not then you're not going to get any measurement worth a damn for BSFC.
Min BSFC is never found at full power. You would never want it to be as automotive engines never run continuously at full power.
I could have sworn this was a cummins 4BT forum.
1 - 20 of 21 Posts
