1 - 6 of 6 Posts
I'll dig it out frrom the garage tomarrow and get you a pic. This is the stock turbo on the 01 Automatic Cummins trucks. it has a 9cm exhaust housing. Yes you are correct it is an HY35w. In stock form it make about 22psi of boost but if you turnbuckle the wast gate which I also still have you can get about 32 psi of boost. It spools very quickly, I has no play and spins freely. I looks just like this one:
I'll dig it out frrom the garage tomarrow and get you a pic. This is the stock turbo on the 01 Automatic Cummins trucks. it has a 9cm exhaust housing. Yes you are correct it is an HY35w. In stock form it make about 22psi of boost but if you turnbuckle the wast gate which I also still have you can get about 32 psi of boost. It spools very quickly, It has no play and spins freely. It looks just like this one:
1 - 6 of 6 Posts
