I have a small block ZF so the flywheel from a 4bt and a clutch from any ford small block manual trans is that correct? What about the starter?I have the flywheel you need for $100. The clutch is just any clutch from a 5.8/5.0L truck engine. Pretty much whatever the trans came out of. I'm assuming this is a smallblock version?
You keep the same starter as your Cummins-to-Ford block adapter has alreadyWhat about the starter?
Well you need to use an 11" clutch which is what most of the trucks used. Mustangs got a 10.5" I think.I have a small block ZF so the flywheel from a 4bt and a clutch from any ford small block manual trans is that correct? What about the starter?
