Just a question for you guys using the zf trannies.
My donor bread van had a Ford T19 setup, When I took out the clutch that came in the breadvan, it was 12" diameter, and the clutch surface was 2.125 inches wide. When I went to the store to get a pressure plate and clutch for the Zf-42, the only thing I could find was 11" diameter, and the clutch surface is only 1.625 inches across - that is quite a difference. Are these clutches holding up against the 4bt torque?
For reference, I'm installing this into a full size dodge truck that weighs roughly 5,000 lbs, and don't plan on pulling anything heavier than a motorcycle trailer, or small camper.
If the 11" clutch isn't right, can someone point me in the direction of a 12" clutch for the zf-42?
thanks
Craig
thanks
Craig
