IS this the Model Zf 5 that i will need for the Swap?
http://cgi.ebay.com/ebaymotors/1987...ryZ33727QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
No; why?does anyone make a shifter kit for the zf5?
Carl Donica just used the stock shifter with a piece of flat bar welded to the bottom of it. Just drill two holes to bolt it to the trans shitfer and there you go.Cause the trans that i am thinking about getting doesn't come with a shifter.
What is a shifter kit? Short shifter?
An ingenius guy could put a Ford 205 input in a dodge 205 case with the 6 bolt pattern or redrill a chevy case.
I have the same issue. I bought a ZF this weekend with transfer case and hydraulics for $350 but it is missing the shifter and the throw assembly that the stick attaches to.Cause the trans that i am thinking about getting doesn't come with a shifter. I am putting a dana 20 behind the zf 5 in my 1970 bronco.
