161 - 170 of 170 Posts
Wow.... looks like an awful lot of weight for a tandem axle. I see the tires on the steer axle are nearly bald as well. And towing in OD is why you blew up the Getrag :nuke:
2/32 tread depth is legal in Wisconsin. I cross the scales at 22-23k combined with my first gen....if I didnt tow in OD I wouldn't get anywhere.....just dont lug her down in OD.
with 10K on the trailer it brings it 200# over the GVWR, darn you got me there...
yes my front tires are getting a little thin, thanks I had not noticed :rolleyes:
why do you just assume I was towing in 5th? the initial breakage occured leaving a stoplight too hard and stripping teeth off the input gear. it was making a ton of noise, and i ran it another 40-50 miles until the reverse idler picked up a tooth and launched it thru the case. i proceeded another mile or so with no oil in the trans to get off the highway (expired trailer tags :eek:) and lost it all coasting into a truckstop. hence the nuclear input bearing and gear. i have a trans temp guage and it never got warm until the gear debris came into play.
Yeah....then I had to load up my old trusty 1st gen. and come and get your busted ass!
I am just figuring out the motor mounts for my own swap. I have 91 dodge mounts and rubber mounts, and i planned on using the chevy mounts slotted out. I have a 2wd truck, so the trans tunnel is def. shorter however right now the motor seems to hit even the firewall. DO you have a body lift?
