I’ll write up directions on how I took my dash out. I dreaded doing this due to never having done it before. It took me a while to find any info on how to proceed.
1. Take the trim off the front of the doors from the floor to the top of the windshield.
2. Take the radio out to unplug the antenna. The antenna cable is held in clips at the
bottom of the dash. Get it free of the dash. Remove glove box.
3. Take the ignition switch out and remove the 2 piece cover on the steering column.
If you have tilt wheel, that handle screws out.
4. 2 screws hold the turn signal handle onto the steering column. Remove them. The
turn signal handle will then stay with the dash with all the other wiring.
5. Take the panel under the steering wheel off.
6. Take the bolt out that holds the steering shaft together. If automatic, take the white
cable for the gear indicator off the column, 7/32 socket IIRC. Then take the 4 nuts
off that hold the steering column in and remove the steering column.
7. The big aluminum thing under the dash is what the steering column is mounted to.
There are 2 sets of wires clipped together and attached to the aluminum thing.
Unclip them. Also unclip the wires to the E-brake and the brake switch. There’s a
big bundle of wires attached to the left side of the steering column and you can
unplug it by taking I believe an 8mm screw out of the middle of it. If you have a
clutch unplug the wires to it too. With an automatic, take the gear shift cable off
to get the steering column out. Behind the aluminum thing are 2 wiring harnesses
coming thru the fire wall. Go to the engine side under the brake booster and a 10mm
screw holds the plugs together. Once you get them apart there’s a clip on the top and
bottom. Squeeze the clips and push the harness plugs inside the cab.
8. Take the nuts off the E-brake and lay it on the floor.
9. Take 3 of the 4 bolts out that hold the aluminum thing to the dash. The 4th bolt will
be the last bolt to come out.
10. On the lower right side in front of the door, unplug the wires and vacuum lines
that go to the dash. Remove the switch for the dome light. Screw it out and then unplug it.
11. There are 2 screws under the dash in the middle, 8mm IIRC. They are attached to
braces coming from the firewall. There’s also a vacuum line and wires there that
need unplugged.
12. There are 4 screws on top of the dash that need removed.
13. There are 2 screws left that hold the dash in place. 1 screw at the lower right of the
dash and the last bolt in the aluminum thing. The second dash I took out just hung
there. Pull it back and lay it on the floor.
14. The cable to the heater needs taken loose. I could not get the little white clip
undone so I took the 8 screws out of the cover over the heater core and was able to
maneuver the wire cable off the flapper. The dash should be free.
