I've got a 92 bronco with an e4od that is still in really good working condition and I'm thinking about keeping it when I do my 4bt swap. Could I get a TCM from a 92 7.3L e4od powered ford and make it work with my trans? I'm hoping this would plug right in and change the shift points to better match the 4bt. Can I do the same type of swap for the torque converter? Then to help the trans hold the power better and last longer install a TransGo shift kit. I have a factory trans cooler already.
