I have a Cummins 4BT with a VE pump.
I'm having a fueling issue.
I ordered new Cummins injectors using my engine # being a Chinese Cummins they use the engine # for reference.
I think they shipped the wrong injectors because no matter what I do to the pump I can't get any black smoke and very low turbo psi.
Here is what the Chinese supplier sent me
The engine#69393982 comes with piston#3926631 which is bore of 102 mm (or 5.4 inches) and a total height of 105.51 mm (or 5.24 inches), it’s the same with 94-98 Dodge 5.9L.
I want to order a correct set of injectors but I need to find out the size of the piston bowl.
The Chinese CPL is 750 FYI
