Since there is no other section dedicated to mercedes engines it it seems like we need a thread here to discuss swaps of the later mercedes mechanical diesels which are commonly swapped.
Short version:Ok I wedged some modeling clay down there and fired up a photo editor. One half of the inlet is 762 mm2. So approx 1524 mm2 total at the inner end of the ramp.
Turbine wheel is 64mm small and 74.87mm large diameter.
Will have to estimate a scroll radius later.
OK thanks Dougal. I've corrected it in the previous post.The A/R you've measured is in cm. Most use inches which is 0.9.
Maybe this will be fine with the two turbos I have if I run it at high boost. My LP compressor is bigger than assumed above, which is good. So it all depends upon the backpressure. I think it should never exceed 2.5x the boost, so it really depends upon whether this 16cm LP housing will flow well enough to keep emp below 160psi at 5500 rpm or so.HX30 Super and HE451. I used 26cm for the HE451 housing which comes out I think around 1.5 A/R.
Big disclaimer for these results. I can't guarantee any of these components will last when used in this manner. The HE451 will likely be fine, but it's going to be a hard life for the HX30 Super and also for the engine, the gearbox, the driver and everything else.
I used 65psi boost and that came out to more like 170cc for the midrange with 155cc at 5500rpm. 17:1 A/F was used throughout.
6000rpm went off the map a little bit for the big turbo, so even though you can spin it that quick, you're well out of efficiency and power making territory.
Because the HE451 isn't wastegated it tends to gain boost with rpm, peaking at PR 2.73 (25psi) at about 5500rpm.
Max boost is still looking like it arrives a bit past 2000rpm. This is going to be scary to drive!
Torque is over 1000Nm from just past 2000rpm to 4500rpm.
Power will peak around 4000rpm where 400kw is expected (540hp).
Drive pressure will top 120psi by 6000rpm, but at 4000 is going to be around 80psi and at 2000rpm drive is below boost.
The HX30 super is on the map the whole time (based off my guesstimate of an HX30 Super Map) with ~35 lb/min max and the HE451 runs just off the map at 6000rpm. This is ~80 lb/min.
But by 6000rpm you're down to ~265kw anyway so you should have changed up a gear ages ago.
So what was used on that engine? Looks peaky!
I haven't had any time to run more calcs.
So I've got a few spare minutes to run some calcs. So is the intent to run the 16cm 451 ungated or with an external gate?
I'll do a run with the 451-16cm ungated at 120cc and see how it looks.
*edit*
So I've run some ungated calcs and this is looking surprisingly good. You'll need a huge wastegate to bypass the HX30 pretty much completely from 4000rpm to 6000rpm.
Power should be around 350kw (crank).
Drive pressure is below boost from 4000-6000rpm.
The 451 runs straight up the middle of the compressor map.
You may or may not find the HX30 compressor to be a restriction at higher rpm. It's too close to call A flap valve to bypass it (with a wastegate actuator set to ~35psi triggered off the HE451) would cure that.
In my calcs I've got the HX30 fully wastegated at higher rpm to keep boost down. Otherwise you'll generate too much boost with them compounding and too much boost robs power. So once a HX30 is fully wastegated it should just be idling around and the compressor geometry that works very well when compressing air becomes a terrible flow path for air that doesn't need compressed.Thanks Dougal. I have been going back and forth on the big turbo selection question.
Eventually I decided to just bolt it up and see how it goes. A guy stamsas in Norway has hx35/hx52 compound on a 606 and there is a dyno run on facebook which has both of them spooling quite late. Another guy Hans Persson in Sweden run straight hx52 but very late spool. All hx52 have 16cm housing, but larger turbine wheel than he451. So I think the smaller wheel on mine with similar housing cm should be about right.
I had not considered the flap compressor bypass until seeing blacksmoke racing on facebook with he221w under hx50 sequential. It has a gizmo like that. Somehow. Does the hx30 super contribute anything at 4000-6000? It is still presumably cranking away at 40psi or whatever. I did get the super so that should help.
Anyway now just have to either build the manifold or get someone working on it.
Cheers,
Karl
*edit*
