41 - 60 of 145 Posts
The rotation can be handled through the drive. Velvet makes left and right rotation drives, or used to. I think it's as simple as a gear swap to reverse the rotation. The only bad thing about having the props rotating the same way is prop walk, where the boat's stern wants to go to one side or the other. It's bad in reverse on some boats. Counter rotating props compensate for that somewhat. It may be possible to re-prop to compensate for the rotation. I don't know. I'm not a prop guy. I would consult a local prop shop.
Good discussion in this thread about dealing with heat. http://forums.tdiclub.com/showthread.php?t=413125
@dieselram94, the earlier 1.9TDI ALH can take a cable throttle. They are the easiest to convert and have the potential to make good reliable power with bolt ons. One thing to note here is the VW TDI has a redline around 4800rpm stock. I think your Chrysler's redline is around 5500 rpm. Is this correct? An MTDI will lose some efficiency and power. Malone in Canada can reprogram the computer to make more power and keep things running smooth and cool.
https://malonetuning.com/ecu-tuning/audi-volkswagen/tdi
A few more links to info. This first one is good, or was good.
CDK is a good fellow to talk to about VW conversions.
https://www.boatdesign.net/threads/marinizing-vw-turbodiesel-engines.19118/
More info from the guy on the TDI forum with video.
https://www.boatdesign.net/threads/vw-audi-1-9-tdi-marinization.52760/
More.
https://www.boatdesign.net/threads/vw-1-9l-pd-tdi-marinizing.50228/
Thanks!!! I’ve been reading through all those links. Very interesting info!
As far as redline goes, I’m not sure! Lol! I inherited this boat from my buddy. He just bought it last summer. We built a junkyard 318 for it just to get it up and running for him with plans to drop in a 4bt. It will be used mainly in Penobscot Bay offof midcoast Maine. So I think being able to plane really won’t matter as it’s usually a bit to rough to plane anyways. I really want to get away from the 22 gallons per hour fuel consumption it’s currently rated at.
...the earlier 1.9TDI ALH can take a cable throttle...
None of the automotive ALH engines were mechanically controlled. The injection pumps were electronic versions of VE pumps, controlled by the ecu via input from the potentiometer connected to the go pedal. That's not to say a mechanical pump cannot be made to fit nor that a cable rigged up to a potentiometer wouldn't work but that, natively, they were not driven by a throttle cable.
Sent from my mobile look-at device
You shouldn't need a mechancial throttle. Keeping the ecu will usually allow more power and more/smoother efficiency.
I also have a flybridge 26 ft carver getting the 2.0 BHW
I will set the throttle assembly near the engine bay and remove the throttle cable off of the back of the block.
The throttle cable will now push the throttle pedal. This keeping the original dual helm controls.
As for cooling, the guy with the searay 25 had perfomance issues with his water cooled exhaust.
Im only water injecting the down pipe.
Even then im regulating it as to only provide enough to cool, excess will be dumped out overboard.
I will have my intake, turbo hot side housing and turbo manifold heat coated with white lightening. This will keep egt away from iat, keeping surfaces much cooler. I will then pack ceramic wool around and under manifolds then lava wrap it in, keeping exhaust away from intake as much as possible. Since they share the same side of the head it will not be perfect.
I will also have a turbo blanket and jacket for downpipe.
If engine bay temps are still too bad or iat goes 60 deg over ambiant temps ill put copper tubing around the ceramic wool with water pumped thru the tubes to help carry away the heat.
Depending on engine hatch temps i may also put one or more fans on the side of the engine hatch to suck in cool air. I also have room for 2 bilge fans i can mount in their to suck out hot air. My hatch is raised off the floor and has a seat on top. Ill just make the seat stretch across the rear transom so the fans wont be seen unless the seat is raised, if the fans are needed. Im not sure if yours is flush with the deck or not.
Ill also dyno mat the entire inside of the hatch to keep down noise and protect everything from heat
Im still seaching for the magic number of what is an acceptable engine bay temp. Many working boats use 100% dry exhasut with diesels.
Because of my hull shape and outdrive my boat does not do well at or under hull sleed (around 7mph) it goes whatever direction currents or winds want it to.
Your boat having a rudder should react differently and if you want it used as a displacement boat (slow efficient relaxing or working speeds under 10mph) you can always play with rudder shape or size which i dont have the ability to do.
From the info white bread posted it's the 01 to 03 1.9 tdi and 04-05 passat 2.0 tdi that are the easiest to swap. For him anyway. Although that price does seem very good.
Ahhh yes, that's right. I was thinking of the early 1.6T. It shouldn't be very difficult to rig an electric trottle to use a lever instead of a pedal. The throttle return spring would probably be the only real issue.
I found a 2006 motor complete with Ecu for 750.
Is this a easy motor to reprogram and make stand alone?
I'm not sure if it's easier, but Malone tuning can help with anwsers. The issue used to be the security programing needing to read the cluster and key chip. I'm not sure if that was ever tuned out in the newer non ALH engines.
I may give Malone tuning a call too. Ive sent several emails and made a phone call to whitebread about tuning and have heard nothing back. I'll be ready to send off my ecu in about 2 weeks.
Make sure you look into mods on the new 2.0 if you are going beyond stock as they are different beasts than the 1.9/2.0 tdi we all know.
The immobilizer delete is old hat for any tuner regularly involved in the tdi game--kerma, Malone, rocketchip, etc.
Rick, I believe you've been speaking of whitbread, as in Matt Whitbread. He runs a shop in the northern Midwest, iirc, and stays busy.
Anyway all of these engines basically swap in about the same and there's plenty of documentation around for the bew or brm engines that you'll find in the 06 tdi. As valuable a resource as 4btswaps is, for tdi engines you can't beat tdiclub.com.
Ok, I found a 2001 Golf with the alh motor. Clean motor, auto trans. Light front end damage. Motor, harness and ecu for $850
I think about 200,000 on it for miles. I’m going to see if I can get a bit cheapee
That's a good deal! The injection pump alone sells for about half that, being as how it has an 11mm plunger. Nozzles are a relatively cheap upgrade and net big returns on performance. When paired with a tune, you'll be in the 160 hp neighborhood for under a grand. Add a turbo and stage 2 cam and you can push into 200 hp territory. If you go much beyond that, you'll be looking at the need to spend big money on things like a block girdle, ASV pistons, forged rods, head studs, etc.
I’m hoping to make a deal on it today. I hope it works out.
I don't think upgrading the internals would be needed on a boat in the 200hp to 300hp range. Even with full throttle out of the hole, prop slip would keep from grenading the internals due to shock loads. I don't think the block would flex as much due to how the engine would be mounted in the boat. It would be mounted by the sides above the centerline of the crankshaft. It wouldn't be hung in like it would be in a car. I've never went full throttle from stop in a boat, except during my knee boarding and skiing days which are long behind me now.
If I ever did this for the boat I want to build, I don't think I would need more than 250hp if I want to run on plane. The areas I would be in wouldn't allow for more than displacement speeds anyway.
I’m looking to create a reliable, economical boat. If it planes, it’s cool. If not I’m ok with it. Honestly I’m surprised the 318 v8 will plane it actually. This boat is over 26’ long and 10.5’ wide. If I remember right the spec is 23 gallons per hour of 3/4 throttle...yikes!!
I’m hoping to use this boat more as a mini trawler though. I’m hoping for about 2.5 gallons per hour at about 10mph?
I understand that. I'm building for the just in case I want to mode.
The boat I'm planning to build has a 30' hull length and 8'6" beam with a flat bottom and a 7-inch hull draft unloaded and 11-inch loaded to max. Recommended power is 150hp to plane. The 27 foot model that was built only used a 115hp Evinrude ETEC outboard to plane. Top speed was 34mph and cruise was 30mph with an economy cruise at 22mph. Most of my speeds will be around the 7 to 10 knot range.
Ok, I can either buy a 2001 alh with 200,000+ miles (automatic) with harness ecm and throttle minus starter and alternator for 850 or a 1999 Jetta with over 360,000 miles manual trans complete car for 500 running, driving. Both need oil pans replaced. Which one you guys think I should buy?
The auto should have the 11mm pump head so that would be better for your power goals.
Reactions: dieselram94
The auto would be the better engine because of the injection pump. The flywheel and wiring from the manual car would make things a little easier. I talk about using a heavy flywheel because a flex plate for an automatic doesn't have enough inertia. Shifting from neutral to forward or reverse may cause the engine to stall, as it bogs down at idle to take the load from the driveline. A heavy standard transmission flywheel will help keep things moving because it takes more to slow that heavy rotating mass down. The 4x4 guys run spec flywheels at 40+ pounds in heavier vehicles like Rangers and Jeeps to prevent easy stalling.
