41 - 53 of 53 Posts
After a lot of research, I managed to track down a 6 speed Allison 1000 from what I believe was a 2007 6.6 Duramax. The trans itself is July 2007 build. It's a 2 wheel drive trans but that will have to do for now, given the circumstances. It's missing the harness (it shouldn't be hard to buy one online?). I'm not sure about the TCM if it's there or not, but would it be a problem if I bought the trans without it? I don't think I'll ever reflash the stock TCM myself or even find someone who would do it without messing things up first. From my understanding I can buy an aftermarket standalone controller, that would come pre-flashed, am I m
A stand-alone harness and TCM can be purchased separately if necessary. If you buy one of the medium-duty controller setups, then they will supply a harness and suitably flashed TCM as needed. That is all relatively straightforward. It just costs money.
My question is, would I have any issues fitting this specific trans to my Cummins (It's an 89 12 valve non-intercooled, intercooler will be added later)?
It's been done umpteen times. Why do you think there would be a problem fitting it to your specific engine?
And what parts would I also need to make the swap. I know this may have been asked a few time before but I can't seem to make a definitive list of parts that I will need to make the swap. Other than the trans adapter and necessary flexplate/bolts, what else would I need (TCM, wiring harness,...etc)? What about throttle input for the trans?
The engine and trans are going into a 1978 Dodge truck, so there shouldn't be any major electrical issues, everything is pretty much mechanical, so I shouldn't have to hack into the wiring harness to make it work with an ECU/ECM.
Any input would be appreciated, I'm about to pull the trigger on the trans but I need to make sure I have everything else to make the swap go as trouble-free as possible.
Excuse the low quality pics, I was sent them by the guy who's selling. I'll go see it in person if it's the the right transmission.
This has all been covered numerous times in this thread, but here it is again:
1) You need to mount the transmission to the engine. You have two basic options: Either use SAE #3 (SAE #2 is too big for most pickups) or the GM bellhousing.
If you choose SAE#3, you need the SAE#3 flywheel housing for a B series front gear train engine, SAE #3 bell housing for the Allison, SAE #3 flexplate and converter/flexplate pilot for the Cummins B series, and the SAE #3 flexplate-to-converter mounting ring (a conical shaped ring that attaches the converter to the flexplate). That is five components. You also need the particular starter for whatever SAE #3 housing you get. I would highly recommend ONLY using an SAE #3 housing with a left-side mount starter to avoid exhaust interference. You will likely have to do some removal of various mounting bosses and protrusions on the flywheel housing. Not a big deal.
If you choose to go the GM bellhousing route, then your only realistic option is the Destroked flywheel housing and flexplate kit. It uses the GM bellhousing already on the 07 Allison you are looking at. The other item needed is an expensive Ford 6.0 Powerstroke starter, which mounts on the right side. You can get the whole kit and kaboodle from Destroked; adapters and electronics for stand-alone operation. I don't personally care for the Destroked stuff (or anyone else's stand-alone solutions for that matter), but it more or less works and is the easiest way from A to B if you want to stick with the GM bellhousing and not shop separately for your electronics. Note that you CAN use the Destroked adapter hardware and another outfit's electronics, or vice-versa. Most guys choose a single source for everything though, for obvious reasons.
2) You need the electronics. ALL controllers will use the OE Allison TCM. There's three basic methods in use: the first is to use a medium duty OS in the TCM which takes throttle inputs directly from a potentiometer-type TPS. Every one of these I have driven shifts just like a medium duty truck, which is to say it shifts like a GM Allison TCM stuck in tow/haul mode. I'm also pretty sure they have no option for a 4WD low range shift schedule. This isn't tragic, but it's nice having a softer shift schedule with different shift points in low range, as well as being able to run the output speed sensor on the t-case output rather than scabbing it into the trans-to-tcase adapter.
The second control option is to use an 8.1L gas OS in the Allison TCM. This gives all the goodies of a GM TCM cal, and allows you to use a common off-the-shelf Cat (or Ford, according to some folks) TPS with a PWM output. The two main complaints with this option are lack of tow/haul without wiring in a compatible BCM or some other box to communicate tow/haul button requests to the TCM, and the fact that the TPS input doesn't give full range on the TCM input. As mentioned, tow/haul can be done with extra boxes and wiring. The apparent limit on TPS input range can be worked around with proper scaling of the calibration tables. It isn't a perfect option, but it does get the job done and I have a few trucks out there running with this setup that I did in years past.
The third option is to use a TCM with the GM OS used in Duramax applications. This requires an interface controller capable of sending the required signals via GMLAN to the TCM. I'm not sure if the Destroked kit uses this method, or method #2 with an auxiliary box, but either can work. If the interface is done correctly, you will have access to all features of the GM OS in the Allison TCM. If it's done correctly AND you have electronic engine controls then you will also have defuel capability, which massively increases the amount of torque the trans can reliably handle.
That's pretty much it.
Yes. Do you have something constructive to add?
Yes, the shifter will be specific for an Allison.
NO IT ISN'T! Please stop posting inaccurate information! If you don't know, then either say you don't know, find the correct answer and post it, or simply don't answer the question.
The six speed Allison can use any six-position shifter with either 3-speed or 4-speed GM-spaced detents, adjustable detent positions, or no detents. Chrysler and Fords use a shorter rotation between park and reverse, so any tightgly gated shifter made for them won't work on the Allison. Most older vehicles with column shifters had no detents on the column shifter itself. It used the detent positioner in the trans itself (the "rooster comb") to locate each shift position. The PRNDL indicator may not exactly line up on a non-GM vehicle, and GM vehicles with 4-forward-speed PRNDL's won't use to the lowest indicated range if properly stopped. See The complete Allison 1000/2000/2400 info and swap guide thread for info. The 6 speed Ally actually has seven detents, but the last one isn't used and an external stop should be installed on the trans or shifter to prevent dropping into the unused position.
If you are using a shifter with built-in detents, whether column or floor, it needs to be compatible with GM 3 or 4 speed automatics. Most aftermarket shifters are "universal", and are capable of being used on common GM 3 and 4 speed transmissions, so they will work fine on the Allison.
If your Dodge column shifter is like the one on my OBS GM pickup in that it has no detents, then it can be made to work. In all likelyhood you won't have to change anything, but it is possible you may have to shorten the trans shift lever a bit. You might have to reverse the linkage, or even convert to cable operation. Those are all possibilities one must confront when doing swaps. Things are rarely all bolt-on.
The 3000 and 4000 series transmissions used completely electronic shifters. Even the "lever" shifters for these transmissions have no mechnical connection to the trans. The 1000/2000 series REQUIRE a mechanical manual shifter connection. The only electronic shifting available is when the manual shift lever is in (M)anual mode, at which point push-button tap shift is enabled.
There are some aftermarket models possibly. The controls are electrical. If you could locate the SAE3 parts, that may be cheaper than the Destroked adapter setup. You'd need the SAE3 engine block adapter, flex plate assembly, and starter for a Cummins 6bt. Then you'd need the SAE3 bellhousing for the transmission which is an Allison part. The 1000 and 2000 series transmissions both used that. If your Allison had come from the GM medium duty Kodiak line it would have had the SAE3. Don't know the part number for that housing, but if there are any GM medium duty truck dealers over there they could find it. The parts on the other side would all be Cummins.
Any Allison dealer can supply the SAE #3 bellhousing, and for a LOT less money than what GM wants for the same part. Be advised that there are two different SAE #3 housings. One has integral cooler ports and an integral filter boss, while the "other has a separate oil cooler/filter adapter plate that mounts to the bottom, and that plate has the cooler ports and filter boss. It also has more ribbing than the "one piece" integrated housing. The latter housing doesn't come with the plate and plate-to-housing gasket, which must be ordered separately. Most apps use the one-piece housing, and it is certainly the cheaper option between the two.
When I said the shifter was specific for the Allison, I was not speaking of adapting the Allison to an in vehicle steering column shifter. All the shifters you see in medium trucks are specific for that transmission. How many companies make a kit to use the old Dodge TF727 shifter with a 6 speed Allison? I couldn't find any.
It seems you misunderstand the difference between the different Allison series and the shifter requirements. The 3000 and 4000 series have completely electronic shifters. They can be either push button, lever (t-handle style), or manufacturer specific. In the latter case, Freightliner, for example, uses their same stalk shifter for both Allison automatics as well as Eaton automated manual transmissions.
The 1000/2000 require use of a mechanical shifter. The rooster comb (detent lever) inside the transmission has the same pattern spacing as GM 3 and 4 speed automatics, such as the TH400, TH350, 4L80E, and 4L60E. ANY shifter capable of operating one of those transmissions can operate a 1000/2000 series Allison.
The Chrysler and Ford automatics are similar to GM units, except for the detent to detent spacing. That said, as long as the Chrysler or Ford shifter doesn't have internal gates or detents, which most don't, then they are easily adaptable to the Allison. The PRNDL indicator may not exactly line up, but that is an easily solveable problem.
None of this is rocket science. If someone is doing an Allison swap, the shifter will be the least of the problems needing to be solved.
Discussion starter · #47 ·
I'll probably go aftermarket, just to be on the safe side, it doesn't cost much from what I found out. Most of the junkyards here are exposed to middle east sun (think Nevada/Texas). It might seem intact, but the insulation is most likely dry and falling apart.
Yeah, I now realize I was being paranoid about it. I just didn't want to spend the money on a transmission that would end up being a boat anchor since no one will buy it off me if it didn't fit my engine.
THANK YOU for this breakdown. This is literally what I was looking for, all the possible options available in one place.
I'll see which one's the best out of the three (cost, parts availability, ease of application..) and go from there.
I just have one dumb question, what exactly is OS and GMLAN short for? It's just so I could look for it in Arabic too if I had to.
I'm looking to install a transmission behind my 6bt (12v VE pump). I currently have the Tf727 that came with it.
My question is, how reliable is the 4l80e behind the Cummins? I'm aware that the swap should be straight forward, Summit Racing have all the necessary parts needed to complete the swap.
Should I rebuild the Tf727 or should I invest in the 4l80e swap?
Where I'm from, Dodge transmissions are virtually nonexistent (47rh/47re/48re), otherwise this would have been the preferred choice.
The truck will be used mainly for highway driving and I'm only looking to make 400-500 hp out of it. No towing or hard launching.
Any input or feedback is highly appreciated.
I had an overbuilt and expensive 4L80e behind an 8 cylinder NAVSTAR which dynoed at 605 ft lbs rear wheel when I did a stock 12 valve I opted for a 47RH because I simply could not trust the 4L80e at higher torque output and since have been building a 47/48RE hybrid matched to a GM NP241c.
The NP241c has a 40 tooth VSS while the Dodge OD/4x4 extension has the electronic VSS to drive my trans controller "no TPS" the 47/48RE is a much better fit than a 47RH with its long OD/4x4 extension.
  • Like
Reactions: 77 wrecker
OS=Operating System. This isn't really the correct term, as the "operating system" used in all Allison TCM's is some kind of RTOS (Real-Time Operating System). What I really mean by "OS" is the system configuration being used. That is, what features are enabled/installed, what type of communications protocols are used, etc. As an example, the TCMs used in GM pickups have configurations which use GMLAN for communications (8.1L units also have PWM inputs and outputs for certain things), have things like multiple shift schedules, 4WD lo-range compensation on the vehicle speed sensor signal, and tap shift functionality, and in the case of 07-up they receive their engine speed from the ECM via the GMLAN bus rather than from a separate input speed sensor in the bellhousing. By contrast, the "calibration" is the data that fills the internal tables, which control things like shift points, shift timing, etc. This is what you change to change the shift points and such, using a tool like EFI Live (or the Allison tool, in the case of a medium duty OS).
GMLAN=GM Local Area Network. This is GM's name for their particular version of CAN (Controller Area Network). GM uses GMLAN instead of the J1939 protocol used by Dodge/Ram and medium/heavy duty trucks. Electrically they are identical: both run over unshielded or shielded twisted pair and the ends of the bus are terminated with 120Ω resistors. The primary differences between GMLAN and J-1939 is that GMLAN runs at a bus data rate of 500kbps vs 250kbps for J-1939, and GMLAN uses some GM-specific packet designators. So, while GMLAN and J-1939 are both CAN protocols, they cannot directly talk to one another. You cannot mix GMLAN and J-1939 devices on the same bus and expect them to communicate. You will simply get bus collisions and no device will be able to communicate with any other. This means that if you need to connect the two systems, you need an interface that can translate the packets and send them down each respective bus in real time. Lets say you wanted to connect a TCM from a Duramax application to a common rail Cummins in a Ram pickup. Because they run at different speeds and some of the packets are different, a microcontroller-based device with two separate CAN interfaces and suitable software needs to be used to bridge the two different buses. That way, packets such as defuel requests, engine speed, and commanded torque can be sent between the two otherwise incompatible networks.
  • Like
I'm going to have to counter some of char's information. First off, a 500HP diesel isn't going to stress a 14b. 14bolts have a saddle bearing on the pinion like a 9" Ford, and this makes the R&P much stronger than an equal size overhung pinion unit like the D70. In fact, the "weak" link on a 14b, which isn't weak by any stretch, are the axle shafts, and those same shafts are used in the 11-½" AAM axle. The 11-½" unit, which is used on 3/4 and 1 ton GM and Dodge diesel pickups, does NOT have a saddle bearing like the 14b. It is a conventional overhung pinion design, and neither the pinion nor the pinion shaft is any larger than the pinion and pinion shaft on the 14b. I could go into a dissertation on why larger R&P is needed for an axle rated at higher GCWR, which has to do with how much tooth contact area the load is applied to on a continuous basis to keep localized temps down for durability, but suffice it to say you won't break the R&P on a 14b and if you break a 14b shaft then you would break an identical 11-½" AAM shaft. As long as you don't plan on towing over 18k GCW or so, the 14b will be perfectly fine. Note that 18k is very conservative, as second gen Dodge guys have routinely towed mid-high 20k range with the weaker D70 without any R&P issues. While I don't mind putting more torque through an axle than it is rated for, I like to stay within the GCWR limits to get essentially indefinite life out of the axle. Also, the 14b and 11-½" AAM use the same pinion yoke, and the 11-½" axles came with 1480 u-joints, so a 1480 yoke can be installed on the 14b if you find you're eating up 1410s.
Forget a 3000 series Allison. These are just too large for a pickup, and the smallest flywheel housing they accommodate is SAE #2 which is also too large for most pickups, unless you don't mind breaking out the Sawzall on the firewall. In stock form the 1000, 2000, and 2400 series have pretty modest ratings, but GM has increased the ratings on the 1000 series to 445HP, 910lb-ft of input torque, and a GCWR of 31,300lbs. Contrary to popular belief, while the 2000 and 2400 series have higher ratings, they all are identical internally except for gear ratios and presence or absence of a park pawl in some models. The park pawl has a weight limit, so it reduces the GCWR of the trans relative to the units without the park pawl. The transmissions with the deeper 3.54 gear sets reduce upstream load, so those transmissions tend to carry higher GCWRs vs the transmissions with 3.10 gear sets. Other factors are determined by TCM programming, which is in turn based on vocational use. Any Allison can be built to handle 500HP/1000lb-ft or so, but its really best to have working torque management. Allison 1000/2000/2400s typically use SAE #3 flywheel housings in non-GM pickup applications. The GM pickup 1000's use the standard GM corporate (aka SBC/BBC) flywheel housing. There were also SAE #2 housings available for these series, but they seemed to be rarely used since the converters on these smaller Allisons fit in the smaller #3 housings. If you are DIY rebuilding an Allison and no hard parts are needed, then the cost is comparable to a 4L80E. The biggest single expense is a good triple disk torque converter. Ally's usually don't need hard parts because they are robust internally. If they do, the price really depends on whether you can locate good used parts or have to spend the money for new. FWIW, Allison wholesaler outlets are MUCH cheaper than GM dealerships when it comes to hard parts. Clutches and steels are usually obtained in aftermarket kits that come with other mods.
500 diesel HP in a 4L80E (4L85E really) is problematic because such an engine will make around 1000lb-ft or more. There are shafts available that can handle that much power, but the main limitation is the OD roller clutch. Especially the later transmissions that uses the clutches with smaller diameter rollers. The torque will eventually blow that roller clutch apart. It's also difficult to get the OD clutches to hold that much torque. It's doable, but like I said even if you get that done it will just blow the OD roller clutch apart anyway. The most tq the 4L85E handled in stock form was 520lb-ft-lbs. That was when the trans was used behind a detuned Duramax in the Express vans. The only reason it was used was because the Allison would not fit on that van chassis.
It's much easier to build a 47RH/47RE/48RE to hold the power because they came behind the Cummins as the stock trans, and the aftermarket has made huge strides to get these transmissions to survive at high power levels. If you're fine with a 4 speed automatic. I'd stick with one of those, built for your power level.
SAE sounds like Oil to me.. as some old guy trying to peice together the info on here.. It appears my cummins has an SAE #3 bellhousing ( I also happen to have a 5.9 24 valve to NV adapter..) want to marry that to a 700r4 that was rebuilt for towing with a 6.2L.. the 6.2l diesel leaks oil like a pig so I'd like to find an adapter to go from the 700r4 to a SAE # 3.. ( with a big heavy flywheel outs some industrial rig... ) if you could tell me where to go, I'd appreciate the assistance....Thanks
Some Old Guy
You aren't going to find an adapter to go from SAE#3 to GM. There's simply no reason to make one since all HD engines use removeable flywheel housings.
What engine is this going on? 700r4's are marginal behind gas engines. Stock 4BT's beat them to death with their torque pulses, while modded 4BT's and any very minimally breathed on 6-cylinder simply destroys them with brute torque. I assume that by "5.9 24V to NV adapter" that you mean you have a standard Dodge flywheel housing for a 24V engine? If so, that housing will work on a B series, whether 4BT or 6BT. All you need is a flexplate and you can bolt up a Dodge 47RH, which is going to be your cheapest route to a 4-speed automatic.
The only practical options for bolting a 700r4 to a B series is either the rare-ish adapters used to mount TH400's to 4BT's in bread van repowers, or pony up 2 grand for Destroked's GM flywheel housing+flexplate+starter setup. Then keep the piggy bank full for the repeated trans rebuilds.
Thanks for the reply: I have a 1984 Chev with a 6.2l Diesel that leaks oil like a pig.. it has a700r4 that was rebuilt by a GM professional to 4L60 + standards.. he said i could tow anything I want.. so I was planning on putting the 4bt on it with a new torque converter with a 1000 stall speed built for beefed up 6.5l s... or so they tell me... and I don't plan to mess much with the 4BT.. I'm not a power guy.. optimize for fuel economy.. will get a grid heater for the Minnesota it will spend time in.. I love my 6bt 12V but Its tuff clutching the thing all the lime with bone on bone left knee... so call me crazy.. some old guy buiding a toy that just needs to go get the groceries.. MY dodge does the Heavy Lifting.. Pat
It doesn't matter if the 4BT is bone stock, 260lb-ft torque, it will still kill a 700 in short order. I've gone through this with a few other guys, and the result is always the same. It doesn't matter what you do to the trans, it won't survive the nasty torque impulses from the 4BT.
You either need to figure on a different trans, or pull the good ol' 6.2 and reseal it.
  • Like
Reactions: SUBRUTUS
41 - 53 of 53 Posts
