Several years ago, I swapped a 4BT/NV4500 into my four-door JK Wrangler. I found a P pump version of the motor that had the HX30W, I was able to fit a small charge air cooler in front of the factory radiator. EGT's can easily get up to 1200° depending on how much throttle I feed it.
The problem I’m having is heat soak into the cab and interior. High temperatures from the exhaust are soaking into the cab of the jeep making it very uncomfortable during the summer months. My center console and floor boards literally get hot to the touch. Probably the only use for the cupholders down there are to keep coffee hot... I wrapped the downpipe before installing, but it’s basically right up against the cab Due to space constraints. Since the fuel tank is on the passenger side of the vehicle, my custom exhaust crosses over and exits on the driver's side behind the rear axle. Before fitting and installing the engine, I added some installation to the front and bottom of the cab mainly because I was worried about engine noise which is also still an issue
I am curious If anybody else’s experienced issues like this after your swap?
Some previous ideas/suggestions were to ceramic coat the exhaust manifold and turbine housing. They also make some heat resistant/insulating paints.
I’m looking for advice on the easiest and most economic fix...
I’ve even toyed with the idea of cutting the hood and installing louvers to direct air flow down from cowl across the front of the cab.
thanks for any input or suggestions guys...
