Of course you are fine with it. Two very disimilar vehicles which give a nice, wide spread in mileage figures. I also doubt they are driven in the same way. They are NOT the best results we have. Not even close. Your assertions that they are a typical difference between a 4 and 6 cylinder Cummins are downright absurd.
You might need to re-read my comments on Lonno's results. He's showing a ~7mpg spread and I expect the differences in weight and gearbox to cover about 3 of those. The 7MPG isn't a typical spread.
You saw Dieseldudes results here:
http://www.4btswaps.com/forum/showt...thread.php?62650-6BT-vs-4BT-fuel-consumption....&p=630666&viewfull=1#post630666
Riddle me this. If there was no significant fuel consumption difference between a 4BT and 6BT, then why did Cummins bother making the 4B? Same question between the 4B and 3B!
I'm fine with mid 20's from a 4BT in certain vehicles. I find most high 20's claims suspect, particularly given the weight, aerodynamics, and tire sizes of many vehicles sporting such claims. I have very good reasons for such doubts. One example was a guy with a K5 that was similar to mine (37" tires, manual trans) claiming 28mpg highway. Having used a G-Tech dyno to measure the overall drag of my truck, I knew how much HP was required to travel 65mph on flat ground. By using the BSFC curves (which, as you pointed out, are best-case) for his 4BT I concluded that 28mpg was physically impossible. Best case, he would get 22.5. The only way to get 28 was to travel continuously downhill. Or with a hurricane tailwind. Or being towed by another vehicle. Take your pick.
Don't forget halfway decent aerodynamics and light weight. Not exactly a valid comparison against a 7k+ lb brick $#!thouse on mudders flying down the highway at 65+mph.
I agree that we have ridiculous fuel economy claims on this site. That's why I mentioned ignoring the out-liers like the example above.
To make 30USMPG (7.84 litres/100km) at 100km/h (~63mph) it's 7.84 litres/hr and you're only producing about 30kw max.
If you get 24kw of those to the ground the vehicle takes less than 88kg of push (~200lb) to maintain speed on a flat road. Aerodynamics are essential, but weight isn't a huge player. My best fuel economy was when loaded to the roof but on a route where braking was seldom required.
Weight matters most when you're braking a lot (burning that hard earned energy off to heat) and having to replace it with more energy from the fuel tank. The extra inertia in larger tyres are exactly the same. I do a lot in the bike industry and many are paranoid about rotating weight vs static weight, but race results prove it's not that big a deal.
Road bike wheel manufacturers have gone for better aerodynamics with fewer spokes and deeper, more aerodynamic, rim sections. More rotating weight, but better aerodynamics and the race results back it up. Conserving energy matters when your engine only puts out 300 watts.
I'm not a road biker though.
Perhaps you shoudl run that engine then? You seem to not have an issue with woefully inadequate power as long as you can wring every last bit of fuel economy from the vehicle.
I do. I own several of these vehicles, one with the 4BD1T, one with the 300tdi and one with the 3.9V8. The V8 is the one I like the least and will be sold eventually. I have some interesting plans for the 300tdi.
Good grief! Do you not know anything about physics? Bigger tires may achieve the same rpm results as taller gears, but they add rotating mass which has to be accelerated by the engine. They are also often wider, adding more rolling resistance. Bigger tires almost invariably reduce mileage, not increase it. Thus the OVERALL effect is NOT the same. Not even close. Thanks for playing though...
I do quite well with physics.
The rotating mass isn't the bogey man people think it is. Unless you're always on the brakes it is no different to mass anywhere else on the vehicle. Bigger tyres have lower rolling resistance. Which is why bigger trucks run bigger tyres. Width and tread pattern are big contributors to rolling resistance but are optional extras.
