Just curious. That's what I've got. Wondering if they will marry...
If so, can you provide pics or part #'s?
You would be ahead money-wise RIGHTNOW. But you'd have $600 tied up into something no one else will ever want should you decide to go with an OD! For $600 you can usually pick up a Ford ZF5 or even cheaper you could get a M5R2 from an F150! GM vs Fprd adapters are usually a wash $$wise. Then you'd just need an adapter to any pass drop TC you choose. Hit up Advanced Adapter for their offerings on that front. You'd gain a plenty stout 5 speed OD trans for a Scout and in demand components that if you ever decided to do something different you can easily get your money back to apply to your next adventure! Instead of "spending" $600 you could be "stashing" $600 and be getting more useful parts. Keep in mind if you can find a set of driver's side drop axles (Grand Wagoneer for example) for a couple hundred dollars like you found the Scout units, that could offset the cost of the Pass drop TC adapter and you could just run a complete Ford trans TC assembly which you can usually get for the same price or just a little more than the transmission alone!I guess I look at it as a lot cheaper than a NV4500. Maybe I'm not thinking it through right. I see it as I need to buy the engine adapter either way. (Which I could reuse if I dumped the t19 later) Then I buy the $100 trans and $500 adapter, so then I have a $600 trans. NV4500's are easily over a grand. Wouldn't I be ahead of the game?
FYI 1st Gens didn't come with an NV4500. They used a Getrag 360. Some poo-poo them. I've personally driven them and used them in work trucks too. They held up just fine to absurd loads that NONE of the gassers in the fleet could touch. Everyone there knew how to drive though and no one was dumb enough to try to use OD with heavy loads. All of those trucks were stock 160HP/400tq 6BTs. My favorite one of them I liked to show people who asked about the Cummins was a 2wd that had a round (cylindrical) fuel tank set in its bed that was just a bit taller than the cab but it had "formed" the wheelwells and upper bed sides to its shape when sat in place! It was about 8' long since it stuck off the bed just a tad. That truck went around riding with the frame on the axle most of the time! The bumpstops were long gone and the welders had put 3/4" plates on the frame and on the axle and a piece of tire tread from something big bolted to the frame for a little cushion. It was relegated to this duty after having served its time as an equipment trailer hauler for long enough to have hit the 200K mark at least and a crew hauler until the interior was completely shot. I don't know how many miles it had since the windows no longer worked and the instrument cluster was covered with dust/mud from living at work sites 24/7 with the windows down! But she still shifted fine and the clutch worked when I quit that job. I asked a guy about it years later and he busted out lauging saying they did some figuring and determined that that truck hadn't had an oil change or any other maintenance than adding fluids as needed in over 5 years when it was sold in a batch of equipment!If you want a nv4500 I "think" the most cost effective way to go is as Twisted said earlier Buy a 1st gen dodge
Steve.
