Caterpillar swap
74K views 162 replies 27 participants last post by  andrewhpaul
#1 ·
Does anyone have ANY info on a caterpillar swap into a pickup.. I have an 82 dodge ram so I have ample engine bay space.. Just need info on what motors would be best and advice on how to get started
Any info will help
#145 ·
Went back to look at beginning posts....... 1/2 Dodge with 3/4 springs. I agree with roachie. Something as big as a 3208 is a bad idea, even assuming it's a good engine (it's not, from everything I've read). A 4bt would be a good swap. Maybe a smaller Cat/Perkins........ did Cat have any smaller engines before Perkins? Either that, or get a bigger truck.
#148 ·
If i bought the 3208 it wouldn't be put in my current truck. I would buy a 1 ton dodge. The 3208 is way too much for my 1/2 ton I agree there. If it was going in this truj I would try the 3114 which I realize is also alittle heavy for my truck. The build won't begin till the end of the summer at the earliest, I'm just trying to gather any info I can.
#150 ·
When dealing with industrial and medium duty or larger truck engines most all of them will come with or have the option for an SAE flywheel housing, usually SAE #2, sometimes #3, and on real big stuff SAE#1. Some engines will come with SAE#4 and that is a small enough housing it is difficult to get a clutch to fit that is strong enough to survive in a vehicle. From there and with the appropriate flywheel you can bolt on almost countless transmissions including Allison, Spicer, Roadranger, Eaton, Clark, and others.
#151 ·
The Allison 545 isn't the greatest transmission for a regular street vehicle. They come in MD trucks and school buses, but lack a lock up torque converter. You wind up giving away a lot of your power just to operate the transmission. You find a lot of those attached to Cummins. They sell you the used engine and give you the transmission because they are hard to get rid of.
#153 ·
There is only one auto tranny that I would consider! The Allison 1000 and its other iterations is bigger and stronger than any of the other "pick-up class" autos. It comes with the SAE bolt pattern or GM pattern comes with or without a park pawl, 5 or 6 speed, various low gear ratios and is stand alone electronic. I picked one up for $700 with the control modules.
#156 ·
On Ebay, out of a burned 07 F-650 w 70k miles. Modules sit on top of trans and showed no heat damage. Owner was a little pissed, but no one bid against me, so I got it for the minimum bid. I had to drive 700 miles to get it, but I smiled all the way!
