VE Pump out of phase?
1 reading
227 views 28 replies 7 participants last post by  Levis
#1 ·
Is it possible that my VE pump is 180 degrees out of phase? Just installed a used but working VE pump. The keyway is in the proper position. The timing marks on the gears are correct. But what I don't know if the VE pump is in phase. I pushed the dowel pin in to lock the gears. Any input is appreciated .... thanks
#2 ·
Here are pics of gear train with the marks lined up with Cyl. #1 at TDC, I do not see any way for you to get it 180* out.
#3 ·
What symptoms are you seeing after pump install?
#7 ·
Recently I had to change a couple pistons and rings and head gasket. (Didn’t touch timing) It was trying to start with sprayed gas. I really thought I screwed it up. Some guy in utube said that first start you need to get it started however. So I got it started and kept it running by spraying gas once a second. After what seem like an eternity (but was probably less than a minute) it started to run like shit. After another minute or so, it ran OK.
I want to stress, I did prime the fuel system and had fuel squirting at the injector caps. Can’t explain it, but I think it’s worth a try. I wouldn’t do this with starter fluid. Just regular gas in a glass cleaner bottle.
#6 ·
If it was not locked when you got it this pic shows relationship between the keyway and pump housing, here si link to page I found it on there is other info that may help located there.
Reactions: SUBRUTUS
#8 ·
Here is what I do; break the fuel line at the ip inlet, prime the lp with the lever or plunger until solid fuel is present, tighten the fuel line back up, then loosen injector lines, turn key on to open fss and continue priming the lp until fuel is present at one injector, this is usually enough to purge most of the air out of the ip cavity, then I proceed to start motor with lines loose for a few revs and then close all lines... if timing is correct it will fire... most starting issues are from trapped air either in the filters, fuel manifold or ip , injector lines will clear out air quickly...
#11 ·
FSS is the fuel stop solenoid... did you get your motor started yet...???
#13 ·
Fueling rate??
You could try turning the fuel screw in also increasing the throttle position with the idle screw I suppose, just be prepared for a possible runaway scenario should it happen.
Compression and fuel injected at the correct time is all it takes with a direct injected diesel, can't think of anything else to check as far as getting it to run.
#16 ·
When you say you are getting fuel to the injectors how strong is it? Fuel coming from the injection pump has to be 245 bar which is 3553 PSI to fire the injector. P pump is even higher. If you crack the nozzle at the injector and only get a dribble then the pump is not providing firing pressure. Could be several issues. Likely ones are air in the fuel lines and the other is the pump solenoid is not opening to allow fuel in. Could be a bad wire or a bad valve. Are you getting a true 12 volts to that valve. Need to look at the meter when you are cranking. If it drops low then the valve won't open. If you have good voltage then the valve being bad is a possible answer. That part is not expensive but a bit difficult to replace. There could be other issues but these are the most common.
#17 ·
... and the other is the pump solenoid is not opening to allow fuel in. Could be a bad wire or a bad valve. Are you getting a true 12 volts to that valve. Need to look at the meter when you are cranking. If it drops low then the valve won't open. If you have good voltage then the valve being bad is a possible answer. That part is not expensive but a bit difficult to replace. There could be other issues but these are the most common.
I had that problem with the Grumman bread van. The +12 Volt power to the fuel shutoff solenoid was intermittent. Rather than troubleshoot an old wiring harness, I ran a new wire to switched + 12 Volts.
I suggest a quick test - Put a jumper wire from the +12 Volt battery terminal to the +12 Volt stud on the fuel shutoff solenoid. If the 4bt starts, you found the problem.
Russ
#18 ·
One thing to consider is solenoid life has more to do with on/off cycles that mileage on unit also off brand units can be pretty hit or miss as to life span.
#25 ·
The camshaft and gear are a interference fit requiring the gear to be preheated for 45 minuets in a 300*F oven to install properly bolt is to be heated to 350*F,
the shaft and gears bore are a straight Dia. so key damage is not as likely.
Looking at your pump keys I'd wager that they were not seated correctly in the shafts keyway and were deformed when the gear was tightened on installation,
not a totally uncommon issue with a tapered shaft/bore assy. keys are much softer than either pumps shaft or gears bore.
They make a tool to R&R cam gear but they run from $600.00 to $1,400 so not for the home mechanic doing it once or twice.
Here is a link to the heat install method.
You can remove the gear with camshaft out of the engine with a hydraulic press, however if you are not experienced with using a press for interference fits
there are many ways for things to south in a hurry and the gear is somewhat fragile when you apply the needed force to separate it from the shaft.
I would think whoever assembled likely did it correctly or it would have failed before now...$.02
#28 ·
Reactions: SUBRUTUS
