Misc. Common Part Numbers for P20 & P30 4BT's
From my notes as removed from various stepvans and postings here on 4BT Swaps:
Air filter - Fleetguard AH-1107 used on the 4BT P30 Stepvan
Barring Tool Hole cover - consists of Cummins#'s - Plug, O-ring-3910248 & Seal, O-ring-3910260
Belt & Fan:
Belt Tensioner, CPL 858, Cummins part# 3934823,
www.rockauto.com, also see
http://www.4btswaps.com/forum/showthread.php?t=4628 and
http://www.4btswaps.com/forum/showthread.php?22659 for more info
The Gates 38513 is the right part # for the CPL 857 & CPL 858 too.
Block Heater, engine coolant, replacement with power cord - NAPA- Balkamp #605-1575
Bracket, Throttle cable mounting, P30 w/4BT VE pump, mounts to rear IP mounting brace - Cummins 3910121
Dipstick:
http://www.4btswaps.com/forum/showthread.php?52130 <=Part# for shorty dipstick
Engine mounts, rubber isolators - Anchor #2710, same mounts as used on Dodge Cummins diesels from 1989-1993
Eliminator, oil filler plug on timing cover - Cummins 3903463
Fan bearing, 1989-1993 Dodge Cummins fan set up, DF0766LUA
Flywheel mounting bolts, Manual transmission - Cummins 3901395, 8 required
Freeze plugs, soft plugs, engine block - Cummins 3922072
Fuel filter, no water drain - Fleetguard FF-5052
Fuel Heater Gasket:
Fleetguard:3834185-s
for bio-diesel:3958485-s
Cummins:3913695
Dodge:4429695
NAPA:1036(This filter gasket will work but thicker; buy the filter and only use the gasket)
These numbers may also work for the dual filter to head seal
Fuel pump [AKA feed pump & lift pump] DIAPHRAGM TYPE, non Cummins replacement, part number
Delphi HFP274, for use with Bosch VE Pump, available at:
http://www.usdieselparts.com/index.cfm/category/812/feed-pumps.cfm and
http://www.commonwealthdiesel.com/store/index.php?main_page=product_info&products_id=223
Other manufacturers part numbers at
www.rockauto.com :
Airtex 1407
Carter M73060
Fuel Pump, electric, 8 psi @ 100 gph, Carter CRT-P4600HP, 3/8" female NPT threads (summitracing.com) Use with lift pump block off cover plate - Cummins Part # 3863441 (or use a Chevy V8 block off plate)
Fuel pump [AKA lift pump] installation parts, low pressure piston type for use with Bosch VE Pump:
- Cummins Part # 3936320 lift pump (qty 1 )
- # 3914753 Fuel Line (qty 1)
- # 3931348 Gasket (qty 2)
- # 3918191 Seals (qty 2)
- # 3914284 Spacer (qty1)
Fuel Tank Replacements:
http://www.gastanks.com
Gaskets:
Gasket, cylinder head, CPL 858, 1268, Cummins part numbers:
3917353 Standard
3915720 .15mm oversize
3915721 .50mm oversize
From Case Tractor:
Change the first 3 to a J
J917353 Standard
J915720 .15mm
J915721 .50mm
Others available:
Fel-Pro head set #FP3804896, Fel-Pro head gasket only #FP3283569
Victor head set #HS4691, Victor head gasket only #4691
SEE REF:
http://www.4btswaps.com/forum/showthread.php?t=4585
Gasket Sets, 4BT Other Sources (NON-Cummins):
http://www.4btswaps.com/forum/showthread.php?t=12563
Exhaust manifold to head gaskets Mopar part #4796511
Turbo to exhaust manifold gasket Mopar part #4429357
Turbo drain flange gasket Mopar part #5003332AC
Grid Heater Relays Used on 1st Gen Dodges:
Mouser Part #: 802-120-901
Manufacturer Part #: 120-901
Manufacturer: Stancor
Description: General Purpose / Industrial Relays SPNO 12VDC, Stancor TYPE 120
Price (2010 in USD) $16.64
Silverlight Page 1,967, Mouser Enhanced Catalog
Supplier: Mouser
http://www.mouser.com
NOTES:
1. If the above links fail then search for 120-901 at www.mouser.com or google "stancor 120-901"
2. Requires 2 relays, ONE per grid element
Hose, Clamps, Tubing, sources:
http://www.4btswaps.com/forum/showthread.php?t=1139
http://www.4btswaps.com/forum/showthread.php?t=6362
INJECTION PUMP RELATED:
Bosch Type A Pump info:
http://www.4btswaps.com/forum/showthread.php?15012-Bosch-A-Type-Injection-Pump <=Isuzu info
Bosch Fuel Injection Publications: http://www.boschtechinfo.com/
Bosh VE Pumps Manual (1.6 MB)
Injection pump
seal kit, VE rotary pump, Bosch DGK-121 also see:
http://store.dieselcare.net/bostrekitfor.html and
http://www.dieselvw.com/PumpSolenoid.htm for complete kits.
The 4 cyl. Bosch VE kit # is DGK126. The 6 cyl. Bosch VE kit # is DGK121 REF:
http://www.4btswaps.com/forum/showthread.php?t=8431
Exploded views and
parts catalog listing can be viewed at:
http://www.usdieselparts.com/pdf/dpe30125.pdf (Note that the link for the dpe30125.pdf document at usdieselparts.com is DEAD!! Might try Googling dpe30125.pdf for possible other reliable sources.)
And the 6BT at:
http://www.dieseltruckresource.com/dev/showthread.php?t=231863
Description and theory & operation
(How it works) available at:
http://www.dieseltruckresource.com/dev/showthread.php?t=231914
http://www.htsuk.plus.com/BOSCH_VE_PUMPS.pdf and same at:
http://members.dodo.net.au/~sclarke7171/files/bosch_ve_pumps.pdf
Diesel Distributor Fuel Injection Pumps - VE:
http://www.dieselbookmarks.com/bombers/VEPump.pdf
Bosch VE type injection pump part numbers to Cummins CPL:
3917530 1986-90 VE Series Rotary, CPL 858, 105 HP 4BT
3908191 1986-90 VE Series Rotary, CPL 767, 105 HP 4BT
3917535 1986-90 VE Series Rotary, CPL 857, 120 HP 4BT
3906631 1986-90 VE Series Rotary, CPL 593, 105 HP 4BT
3919716 1991-93 VE Series Rotary, CPL 1260, 105 HP 4BT
3926831 1991-93 VE Series Rotary, CPL 986 & 1848, 120 HP 4BT
Dismantle & reassemble pic at:
http://www.vwdieselparts.com/forum/viewtopic.php?t=6694 and 6BT at
http://www.competitiondiesel.com/forums/showthread.php?t=26752 This is for the VW version which is 90% the same.
http://www.pnwjeep.net/forum/viewtopic.php?f=51&t=26570 VE Governor spring install
Injection Pump
"full power screw" Bosch part number: 1-463-402-423(-000) & priced around $20. Also see:
http://puredieselpower.com/dodge-pr...m/dodge-products/89-93-dodge-5.9l-cummins-extra-long-fuel-adjustment-screw.html
Injection pump removal & installation video (includes Dodge-Bosch VE 6BT warranty info) Part 1:
http://www.youtube.com/watch?v=mquLrWG4ago and Part 2:
http://www.youtube.com/watch?v=dim4muHRdf8&feature=related and Part 3:
http://www.youtube.com/watch?v=x3UuMgm8BZc&feature=related
http://www.youtube.com/watch?v=NGRyzSKI7FU <=Fuel system troubleshooting
Resealing a Bosch VE Injection Pump:
http://crustycrank.com/resealinjpump.htm#injpump
http://www.dieselgeek.com/TDI_Injection_Pump_Head_Seal_Replacement.htm <=VW Bosch head seal to body replacement instructions
Bosch VE Governor Cutaway:
http://www.youtube.com/watch?v=6j0vrfaXPmw&feature=related
Bosch P-PUMP Performance Troubleshooting:
http://www.youtube.com/watch?v=UPNMLTlhv4M&feature=mfu_in_order&list=UL
HPCR Dodge Cummins Common Rail Diesel Injection Systems:
http://www.youtube.com/watch?v=eMbB4UMZMpI&feature=mfu_in_order&list=UL <=Description & operation
Bosch Injector:
VE type
return line sealing washer, U shaped double washer, Chrysler part# 4429380 AB
Return Line Copper Washers is the same for 6BT and 4BT - Cummins #3903380
The complete
4BT Fuel Injection
Return Line Manifold is Cummins P/N 3909695
INJECTOR DUST SEALS PART NUMBERS:
http://www.4btswaps.com/forum/showthread.php?74721-Injector-install-parts
CPL 593 injector info:
9mm Injector Assy is: 3909509
--Nozzle: 3905436
Per Cummins, 7mm replacement has superseded the 9mm: 3919345.
--Nozzle:3919346
The adapter sleeve for 7mm tips into a 9mm head is 3919358.
Cummins CPL 857 4BTA With JWAC Injection line part numbers; see:
http://www.4btswaps.com/forum/showthread.php?95777
Bosch VE injection pump woodruff key part number: 1460023307
Bosch VE Governor Spring Part Numbers:
2800 RPM 1-464-650-386
3200 RPM 1-464-650-366
3800 RPM 1-464-650-374
4200 RPM 1-464-650-354
Current part numbers used in December 2009. Use at your own risk. Available through your local Bosch Pump Shop and some Cummins dealers. Also note: The RPM is the set defueling point of the injection pump and NOT the maximum RPM attainable. The maximum RPM can vary in excess of the defueling point based on your pump adjustments. Past heavy fueling cases have been reported to result in 200 to 400 RPM's past the governor spring's defueling set point. Ref: DTR, 1stgen.org, & 4BT Swaps forums.
Bosch VW Injector Pump Governor Operation:
http://www.4crawler.com/Diesel/Governor/index.shtml VW but same principles
VE Pump Shaft Machining:
http://www.youtube.com/watch?v=b_kVseGmVmI
Cummins 4BT Intake Cover for use with CAC:
Intake cover for a 4BTA 120 hp PN# 3921500 for use with grid heaters.
Cummins 12-Valve Fuel System Troubleshooting:
http://www.youtube.com/watch?v=9w3JEvANXC8&feature=related
http://www.youtube.com/watch?v=QFE-3t8H140&feature=related
http://www.youtube.com/watch?v=9Mx7BSWUfc8&feature=related
5.9 I6 Cummins 24-Valve Diesel Engine:
http://www.youtube.com/watch?v=j3E7Q2DzZQ8&feature=channel
http://www.youtube.com/watch?v=VwV2qJ-0iY0&feature=channel
http://www.youtube.com/watch?v=sWbbQqahdNo&feature=channel
Oil Pressure Regulator Gasket Source:
http://www.4btswaps.com/forum/showthread.php?27255
P30 Engine & Chassis Replacement Parts; Clutch, Transmission, Mounts, Flexplates, Brakes, Springs, Engine rubber mount cushions, etc
http://www.uptimeparts.com/Portals/0/UpTime Catalog.pdf
Power steering pump, (pump only, no mounting bracket) 1989 4BT, Cardone 208709 possibly updated to Cardone 20-860
Power steering pump, (pump only) 1992-1993 Dodge Cummins replacement, Cardone 208001
Publications, Cummins, Manuals, Operation, Maintenance, Service, Troubleshooting, Parts:
Manuals, service, operation, etc website:
Cummins Service Publications
http://powerstore.cummins.com/service.html
http://www.endurancepower.com/media/CATALOG_CUM.pdf <=Online parts catalog
The CUMMINS part number for the 4b INDUSTRIAL parts catalog is 3884232.
Also check:
http://www.abebooks.com for used & out of print. Search using the word: cummins
NOTE: Prices there vary from dirt cheap to extremely outrageous.
Pulley, Delco alternator, 2.625" od x 1.750" deep - Cummins 3909361
Radiator hose, bottom, one piece - Carquest 21731 replacement used on P30 Stepvans
Radiator hose, top, one piece - Carquest 21729 replacement used on P30 Stepvans
Also see:
http://4btswaps.com/forum/showthread.php?t=7382 for additional rad hose part numbers
Radiator outlet-upper, thermostat housing:
Points straight up - Cummins 3285102 (replaces 3903756) also see 3914409
Points forward toward rad - 3914414, 4BT P30, Also see
http://4btswaps.com/forum/showthread.php?t=4529
Points toward drivers side (USA) - 3920353, 92 & 93 Dodge Cummins 6BT, with IC
Points toward passenger side (USA) - ???????, 89 to early 91 Dodge Cummins 6BT, without IC
Radiator inlet-lower hose:
Points straight outward - Cummins part #3916625
http://www.4btswaps.com/forum/showthread.php?t=8209
Radiator and Coolant Machined Hose SIZE Adapters:
http://www.4btswaps.com/forum/showthread.php?14385-Source for radiator hose reducers;
http://www.jagsthatrun.com/Pages/Parts_Cooling_TransHoseSplicers.html
Starter spacer, 16 mm thick, P30, Cummins 3906647
THERMOSTAT:
CNH [Case-New Holland]part number 47616858
Thermostat Replacement with Dodge Part Numbers:
http://dodgeram.info/tsb/1994/07-07-94.htm
Thermostat housing gasket:
Cummins 392020; Fel-Pro 35526
Timing Cover Oil Filler Plug & Gasket:
http://www.4btswaps.com/forum/showthread.php?24413 <=Timing Gear Cover Plug Part#
TURBO Master OEM Application Information. AKA: What's this turbo part number fit:
http://www.dieselevante.it/turbochargers.asp?idturbo=H3534960/
4" 6BT Cobrahead Exhaust Head Elbow, short bend points down
Cummins Part Number:
Elbow # 3921534 (OLD)
Elbow # 3927862 (NEW)
Found on 8.3 Cummins in ford, freight, RV, Rear Engine Bus
Valve cover with oil filler consists of:
- Cummins 3928405 (replaces 3902605) valve cover;
- Cummins 3901895 cap;
- Cummins 3936876 seal
The following part numbers are found in the Ford 4BT automatic transmission vans. Info from the Yahoo 4BT group. I have no additional information:
Adapter - 3912601 FH9043
Flexplate - 3918957
Clamping ring - 3904361
Crank adapter, (hub?) - 3907620
Torq converter adapter - 3907619
Flywheel Ring Gear # 3905909
The following part numbers are found in the GM TH400/475 4BT automatic transmission vans. I have no additional information:
Flexplate 3918957
Spacer 3907701
Clamping ring 3904361
Wave ring 3908124
REF: http://www.4btswaps.com/forum/showthread.php?17259-th400-part-numbers
Note: Cummins referenced part numbers are frequently updated by Cummins so these listed numbers may only provide a starting point for cross referencing.
Cummins Engine Part Numbers to Case Tractor Part Number Conversion System:
Use the Cummins part #'s. Just change the first "3" to a "J"
So as an example Cummins part# 3928405 becomes Case Tractor part# J928405
